Got told Ipod adaptor wont charge ipod!!
  • Got told Ipod adaptor wont charge ipod!!
    Hi
    I have a polo GTI 2007
    This morning I took it in for some warranty work.
    I've always wanted to have at least an aux input into stereo so I could plug my MP3 player in. I know they are around but not in Australia and I would have to find someone to fit it.
    Anyhoo I'm planning on buying an iphone so I just asked if they could fir the ipod adaptor in for me which they will but they reckon it will only work to play songs and will not actually charge the ipod at all!!
    I've googled and found a volkswagen original accessories website and its got the ipod adaptor listed there and it even says there it does charge the unit..
    Does anyone know if they brough out different models ones which do and dont charge? It would be annoying if if didnt charge the iphone as I would have to unplug it to charge it and then cant listen to music
    Also is there anyway I can get some sort of convertor plug which allows normal aux input 3.5mm so I cna plug any device in and play music?
    Thanks
    The newest generation iPods and iPhones charge differently. What do you have? Even if you have a new one though you can get little adapters that mean that an old adapter will charge a new device. Cablejive sell them. As they are a little bulky I bought an extension cable from them too, put the adapter in the middle and plug the ext. cable into the iPhone / iPod.
    Don't think you can plug a 3.5 into the ipod adapter, could be wrong though...
      Thanks actually, I don't have an ipod yet I was going to buy the iphone and use that but now that I found out it wont charge I was thinking of just buying the cheapest 8gb nano and using that only since it can play for up to 24 hours before needing recharge..
      However I might check out that convertor thing you speak of thouhg.. Thanks!
        http://www.cablejive.com/charge-converter is what you would need.
          Thanks again
          Just out of curiosity, which gen versions of ipod nanos will charge with the vw adaptor and also be compatible.
          I say this because since I dont own an ipod yet, I might just find a second hand one on ebay.
          Cheers!
          EDIT:
          Sorry thanks for your help but I ended up cancelling the adaptor.. they rang back and quoted me $395!!! I think that's a bit steep for a cable..
          I have heard there are aftermarket cables you can get which connects to the CD Changer port and terminates to a 3.5mm plug.. I am going to try find one of those instead
          If I cant find it maybe when I get my iphone and one of those charge convertors I will look into it again
            I *think* it's just 4th gen nano, 2nd gen touch, and iphone 3G / 3GS, but I'm not 100% on that.
              Thanks for reminding me to order one, I just have been meaning to but have forgotten on so many occasions.
                Originally posted by clone_tk422 View Post
                Thanks again
                Cheers!
                EDIT:
                You can get aftermarket iPod adapters for VW that are a fraction of that price and fit it yourself. E.g. www.xcarlink.com.au They have 2 models for VW, not sure which one you'd need, you'd have to ask him, but they are only $80.
                  The only drawback of those xcarlink adaptors is that you can't control your ipod from your ipod interface. You only have limited access by using the controls in the Head unit to play playlists. ie. you can't search by artist, album, song, etc.
                  Xcarlink look a bit sketchy as well. Read the below thread. I wouldn't hand over money to someone that has not had contact details available for that long.
                  http://www.ozaudi.com/forums/showthread.php?t=19297
                    I had an Xcarlink in my Mazda - no problems with them at all.
                    And you CAN control from the iPod by setting the CD changer to CD1, which passes control back to the iPod. The other "CD"s play playlists.
                    There are others out there too.
                      What about this one?
                      Would that do the trick?
                      I see that most of them come with an adaptor of some sort but I don't see why this one wouldn't work.
                        Yup saw that one thanks but that's fore pree 2004 polo. 2004 onwards has the flat plug and 12 pins or something
                        Anyhoo that xcarlink is the product name not the company and I saw one on ebay for sale.. Granted its $150 over the $80 charged at xcarlink.com.au but as the other posted pointed out seems no one is manning that website
                        But the xcarlink one looks the bomb has both an ipod adaptor and an aux input so you get the best of both worlds
                        I'll be surely buying that one
                          i have an Eclipse head unit with the ipod link in the glovebox...was told that it wouldn't charge my iphone
                          so...i tried anyway...once plugged in the phone displays a box saying the think you plugged it into won't work with this device so i just ok'd it and it works just fine!
                          Not sure if the same would happen with an OEM headunit...go to the dealer with an iphone and try it out
                            If you are after a Charge Converter from CableJive.com - use this discount coupon code to get 15% off until 15th of August.
                            15% off code: 1500CJ
                              Apple changed their charge voltage from 12v to 5v and the VW adaptor is still in 12v. You iPhone will connect and work but not charge.
                              Thanks
                              Old: 2003 V6 4Motion Bora, Nissan X-Trail, 2002 BMW 530i MSport
                              Current: 2007 TDI Passat Wagon, 2005 Mk 5 GTI
                              sigpic'92 5dr Mk 2 GTI
