Does anyone know what the output voltage is for an iPod so as I can match it to the optimum input voltage level for the MDI interface?
I now have mine set at 0.7Volt but is this the correct input voltage for the iPod? As far as I can tell, there is no info on the iPod that states what the output voltage is of the output, so it is a bit of a hit and miss affair.
When I had the MDI interface installed, they had the input voltage set at the highest 1.5Volt, probably the default setting as a safety feature so that you are less likely to overload the input, but it was always too quiet. It wasn't until I started playing around with the "Setup" for "Media" that I discovered that you could alter the input voltage. Now, thankfully, the output of the iPod more closely matches the radio so that when switching from the iPod to the radio I don't get blasted out of my seat due to the fact that the radio is much louder at the same volume setting as the iPod. Not only that, I can now get the volume up much louder!
I did try the iPod at 0.3volts, but I think it was clipping and sounded a bit distorted with loud passages of music.
