Originally posted by Pepe
									View Post
Summary of Bluetooth Options for RNS510 & RCD510
Mine's a Mk6 R.
I don't know about in the Mk5, but in the Mk6, there's holes cut in the carpet down there that are the perfect size for the connectors to fit through (the holes are just cut, they don't remove the carpet from them). I can only assume they are for BT fitment, as they are exactly where they need to be.
Pepe
Photos of the long trim piece would be good so I know which bits you are talking about. Also of the hole etc near the gearstick. When you feed down under the carpet to the cutouts under the seat, were you able to easily slide the cable through or did you have to remove other trim to get your hands under the carpet to pull it through or alternatively poke some stiff wire through to drag the cable through ?
hi, i'm now considering the under driver seat install. I've got a 1z0 035 729 b as it's for a mkv golf with red mfd.
is the bracket part number any of the following or something else?
1Z0 035 815
1K0 919 737M
will the cover 1Z0 971 813 62u fit?
Thanks!!!
Mate - look a few pages back in this thread for the bracket we'e been describing that cost us about $27 from VW Dealers in Oz. At the end of the day, it's a lump of foam with 4 bits of velcro stuck on it to secure it to the carpet. From what I understand, the "b" Bluetooth unit is in the same size/shape casing as our "c" 9w7, so the bracket should fit fine. Just get the partnumber a few pages back.Originally posted by noisuf View Posthi, i'm now considering the under driver seat install. I've got a 1z0 035 729 b as it's for a mkv golf with red mfd.
1Z0 035 815
1K0 919 737M
Thanks!!!
Yep, I concur with that, everything I've seen on the net shows the 9W3 kit you have should fit that foam bracket.Originally posted by fergus View PostMate - look a few pages back in this thread for the bracket we'e been describing that cost us about $27 from VW Dealers in Oz. At the end of the day, it's a lump of foam with 4 bits of velcro stuck on it to secure it to the carpet. From what I understand, the "b" Bluetooth unit is in the same size/shape casing as our "c" 9w7, so the bracket should fit fine. Just get the partnumber a few pages back.
I have my car booked in at Barloworld Glen Waverley to have the Bluetooth and RNS510 installed.
I will let you know how it all goes.
Is there anything I should stress to the service department?
Like:
- Making sure the RNS510 directions are shown on the MFD?
- Making sure the streering wheel controls work on the RNS510?
- Making sure that the bluetooth menu is displayed on the RNS510?
- Making sure that the bluetooth menu is displayed on the MFD?
- Making sure that the Climatronic settings are displayed on the RNS510 screen when you change temp's and different air direction?
CheersMK6 GTI 3 Door - Candy White - DSG - Sunroof - 18" Detroit - ACC - PA - RC - MDI - BT - RNS510.
OPS if you have parking sensors (no idea if it's possible to do this, just speculating)Originally posted by sharkablue View PostI have my car booked in at Barloworld Glen Waverley to have the Bluetooth and RNS510 installed.
Like:
Audio screen shows on MFD with info from the RNS
Other than that, can't think of any others, your list is pretty comprehensive.
Ahh thanks for that. Reversing Camera is also something else I need to stress to them.Originally posted by Pepe View PostOPS if you have parking sensors (no idea if it's possible to do this, just speculating)
I am sure they wont be THAT incompetent, but you never know...MK6 GTI 3 Door - Candy White - DSG - Sunroof - 18" Detroit - ACC - PA - RC - MDI - BT - RNS510.
Car had its first service today and the dealer had no issues coding my bluetooth kit. Cost $60 to code and test... works an absolute treat. I love being able to mess with the settings which is something you can't do if you don't get the coding.
						2008 Mk5 Golf .:R32/ BMP/ RCD-510/ More to come
Peteaussi - which dealer did you go to? I'd love to get the coding myself.
I can fiddle with SOME settings using the RNS, but it sounds like there are more?---
Tiguan 103 TDI Biscay Blue, Black Leather, Xenon, 9W3 BlueTooth, MDI, Fogs, RNS 510, Comfort Pack
I went to Osbourne Park VW which is where I bought my car. I was having it's 7500km service so asked if they'd do it and it appeared as if they did that type of thing pretty regularly as they could give me a price straight away and didn't ask any questions. Some of the settings you can access only through the MFD are:Originally posted by veebs View PostPeteaussi - which dealer did you go to? I'd love to get the coding myself.
- Changing ringtones
- Changing the name of your device
- Uploading a new phonebook and changing whether or not it reads first name, last name, or vice versa. I have my phone set as first, last and as stock my RCD phonebook was coming up as last, first so this is something I like a lot.
- Change bluetooth settings - Visibility, which devices are paired, etc.
- Go through the phonebook on the MFD
- Input a number to dial from your steering wheel
Etc etc.
Cheers,
Pete2008 Mk5 Golf .:R32/ BMP/ RCD-510/ More to come
Sounds worthwhile - will definitely ask them about it. I hope John Huges can do the same (bit closer to home). Funny you should mention the ringtone - since upgrading the phone software, the car rings with the same ringtone as the mobile (iPhone 3GS with iOS4.1)Originally posted by Peteaussi View PostI went to Osbourne Park VW which is where I bought my car. I was having it's 7500km service so asked if they'd do it and it appeared as if they did that type of thing pretty regularly as they could give me a price straight away and didn't ask any questions. Some of the settings you can access only through the MFD are:
Etc etc.
Cheers,
Pete---
The car was dropped off this morning to have the Bluetooth and Sat Nav installed. I will let everyone know tonight how it went.
Fingers crossed I don't need to go back to the dealer to get anything else done which they happen to forget...
I did stress to them that if they had to ask any questions, to call me at anytime, so we will go from there.MK6 GTI 3 Door - Candy White - DSG - Sunroof - 18" Detroit - ACC - PA - RC - MDI - BT - RNS510.
