Ok, I have my amp sorted for my sound system upgrade so all I need is a Sub now. My amps sub channel is rated at 200w RMS and I am after a 10" unit in a compact removable sealed box. Check out the selection in this link and offer your suggestions http://www.sonicelectronix.com/cat_i...r-systems.html. All info appreciated and hopefully this will be a handy thread for others.
Which subwoofer should I choose?
One great tip is sensitivity. Rarely do you have too much bass, all the time, with one subwoofer. Often, you'd like a little more. Pick a sub with as high a sensitivity as possible, you can always tone it down a bit, usually you're trying to extract more!!'
The volume it recommends is always handy, unless you want to lose your boot.
200RMS bridged?? at 4 or 2 ohms??Last edited by Greg Roles; 07-06-2009, 03:48 PM.2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
here's the amp specs http://www.sonicelectronix.com/item_...HA555PnP-.html
Would a high quality 8" sub in a small sealed enclosure be adequate enough bass for the Golf? Realistically it's not a huge cabin and it is sound quality I'm after.I used to be indecisive - now I'm just not sure....
Your looking at the wrong subwoofers if you want sound quality
That sony at the top of the list is a horid subwoofer!
Keep in mind thats my opinion from hearing that in a store, not a car.
Most "high quality" 8" subwoofers will need much more than 200rms to run.
Peerless would be worth looking into if you were after high SQ with low input power.
What kind of music do you listen to?
And
What budget did you have in mind?
That info will help narrow down your search.Joe Bellissimo
Lol..Don't worry, would never get something like a Sony sub. I was steering more towards the JL ones.Originally posted by shoppingsecure View PostYour looking at the wrong subwoofers if you want sound quality
And
Another forum member has a Image Dynamics 8" sub in a sealed enclosure that I may be interested in at the moment. It's a 2 ohm sub and but seeing as I don't know too much about specs etc I am unsure if my amp can run it. My amp can run at 2 and 4 ohm according to its specs. Do amps select what ohm they run at automatically or do the speakers have to be wired in a certain way. Sorry if this sounds like a stupid question. I guess what I'm trying to find out is will the THA555 (5 channel amp) run the standard speakers at 4ohm (?) and the 2ohm sub at the same time with no worries?I used to be indecisive - now I'm just not sure....
Whatever load the speaker places on the amplifier will define how much current will pass through. Lower loads will allow more current but if its too low then the amp will shut down since it wont be able to handle the current.
That was probably a bit cryptic, post back if you didn't understand that.Joe Bellissimo
Just to make sure I got it right.Originally posted by shoppingsecure View PostWhatever load the speaker places on the amplifier will define how much current will pass through. Lower loads will allow more current but if its too low then the amp will shut down since it wont be able to handle the current.
The amp will sense what load it needs to deliver and act accordingly even if the speakers have different ohm requirements.
My 5 channel amp is rated at 50w x 4 +200w x 1 at 4 ohm or 65wx4 + 250w RMS at 2 ohm. So.....it should theoretically be capable of delivering 55w to the four 4ohm speaker channels and 250 to the single 2 ohm sub?I used to be indecisive - now I'm just not sure....
That's right TDI the amp output is load dependant per speaker. I have 3 ohm fronts, 4 ohm rears and the sub is running 2 ohm, from the same amp.
Sweeping statements like 200rms "isn't enough" is a bit general. It depends what you do with the energy! A sub with a sensitivity of 85db at 500rms isn't going to be as loud and thus noticable SQ wise as one with 93db at 100rms. Sensitivity is the volume of the sub per unit energy. Usually overlooked, and THE reason my little bostom 8" sounds so damn good, it has highish sensitivity amongst other things. It's dual voice coil, and I can hook it up as 8 ohm with 500rms, or 2 ohm with 250rms. Guess which one sounds the best? 2 ohms, lower power, higher sensitivity! The ears just don't lie.
Also amp ratings are often like dyno power, depends how you measure it on the day. Some amps read higher "in real life", some lower.
Finally a cheap sub, well installed in correct volume etc, will usually sound better than an expensive sub with a poor install. I have actually had a GREAT sound from a supercheap sony sub, in a setup I built for my heavy metal brother. He was on a tight budget, but flogs his sound systems. I took great pains to get the correct specs, built a solid box, and set it up right. Even I was amazed a $100 odd sub could simply SOUND so good with his megadeath major hard core stuff he's into. It didn't blow up! I tend not to worry so much about brand, but go on the specs, reviews, internet research and what is going to best suit the space I have available on my budget. One of the best sub results I've ever had, and I've had a lot of subs since starting in 1987, was a $150 Jaycar sub. The sound output, response and just sheer sound was mind blowing for the cost. Perhaps I just fluked the perfect box, who knows. What I'm trying to say is people get too caught up in brand, sure a Hertz or DD is going to be "fat", but I hope your wallet is too!
In the end for me, it all comes down to the SOUND. Law of diminishing returns applies, first hundred buys you a lot, next hundy, a bit more, etc etc.Last edited by Greg Roles; 07-06-2009, 09:28 PM.2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
To answer your actual question TDI, I find a decent longer throw 8" just fine in the Golf. Depends just how "deep" you want the sound to be. It's simply not the ferocious bottom end of say a decent 12" in a 30L plus box, but it's tight, punchy, and the blend is just seamless. Small sealed volumes too, 8-10L. The sound is "full" without me sounding like I obviously have a fooly sik sub bro. I have a full sound, not a doof sound.2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
Sounds perfect and exactly what I'm after. Think I may go for the Image Dynamics 8" sub that's on offer.Originally posted by cogdoc View PostTo answer your actual question TDI, I find a decent longer throw 8" just fine in the Golf. Depends just how "deep" you want the sound to be. It's simply not the ferocious bottom end of say a decent 12" in a 30L plus box, but it's tight, punchy, and the blend is just seamless. Small sealed volumes too, 8-10L. The sound is "full" without me sounding like I obviously have a fooly sik sub bro. I have a full sound, not a doof sound.I used to be indecisive - now I'm just not sure....
At a "reasonable price range" I'd buy any of the follwing 8" subs:
Boston, RE, JL, Focal or the Image Dynamix you mention. All nice units for SQ and to blend in with the rest of the system. My boston is on sonix for $70 US!! but at 87.5 at 4ohm its the lowest sensitivity there, Image 91.5db and Focal up at 93db! You have some great choices in the low volume smaller subs.Last edited by Greg Roles; 07-06-2009, 09:27 PM.2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
Hertz make a nice 10" but I haven't auditioned any of their 8" subs. Then again the box volume needed for a Hertz sub is pretty low so might work out about the same? Pretty reasonably priced at around $250-$350 and very clean sound.2008 VRS Wagon. Yellow, very yellow!
Forever blowing bubbles.
This is very true, I had a 10" JL in my Golf which was an excellent sub but the extra depth I get from the 12" Hertz in the Tiguan is AMAZING. The box size isn't all that much bigger either.Originally posted by shoppingsecure View PostMake sure your going to be happy with an 8".
I'm learning this the hard way but there is no substitute for surface area!2008 VRS Wagon. Yellow, very yellow!
Try this :Originally posted by cogdoc View PostAt a "reasonable price range" I'd buy any of the follwing 8" subs:
TS Parameters: http://www.vibeaudio.co.uk/support/m...paramaters.pdf
Available from these dealers: http://icedistribution.com/dealerslist.html
RRP for SQ8Active (amp included) $449.00
RRP SQ 8 inch sub on its own (no enclosure) $229.00
These are 'arguably' the best 8 inch drivers in the world. (quoted by a leading industry expert)Last edited by ICEDIST; 09-06-2009, 12:27 PM.MK6 Golf GTI ///Adidas | 9N Polo GTI | 96 Seat Ibiza 8v GTI
Quote of the day, from my wife.... "Stop washing your car... it's going to rain anyway"
