This is just a heads up for anyone trying to diagnose a failed reverse camera.
The Park Assist system on my B7 Passat stopped working (beepers, proximity indications and reverse camera). After many hours of troubleshooting I tracked it down to a dead reverse buzzer. It's just a 50 ohm, 36mm diameter mylar speaker. Mine was open circuit. That was enough to cause the Park Assist system to fail its power-up test and shut the whole system down. It was giving error code 1080340. I can't believe VW would design the system that way.
To make things worse, the buzzer is located under the rear parcel shelf. To access it you have to remove the C pillar trims, bench seat, side airbags and the parcel shelf. It's an incredibly stupid place to put it. Had VW mounted it from inside the boot it would have been a 2 minute job.
I have pulled the buzzer cable back into the RH wheel well where it exits from. I will mount the replacement buzzer in there so if I ever need to replace it again it will be a simple job. It won't be as loud, but I had the beepers switched off anyway so I don't care. Currently there's a 47 ohm resistor plugged into the socket. That tricks the system into working.
Hope this helps someone one day.
