Thanks to the knowledgeable users here I was able to locate and find out that the fuse might need replacing - the metal thing inside seems to be disconnected. The car is still under warranty till April 2020 but I thought I’d just replace it myself to save some time if not too expensive. So where do we get the part? Does it have to be genuine from VW parts? Thanks for the advice in advance.
Fuse for 12V socket in MK7 Golf 92TSI
Whilst a blown fuse usually indicates a circuit overload, it can also be just a weak unit and fail for no obvious reason - such as being repeatedly heated close to failure point.
Since fuses are still cheaper than time, unless the reason is clear what I usually do is just replace it and investigate if it immediately blows again.
You put the same in as came out other wise next time you may come out ot a pile of smoke and ashesOriginally posted by Youdotinmymirror View PostThanks for the advice again. I’ll look into it if it does again with the new one. Would replacing it with an 30A fuse be ok or does it have to be 20A? I’ve got an 30A fuse which would fit but wasn’t sure if it’d be ok to use it.
They put different ratings in for a reason2021 Kamiq LE 110 , Moon White, BV cameras F & B
I thought so too, as it’s meant to cut it at 20A but would allow up to 30A and then burn and cause fire. My mechanic told me it’s ok but it didn’t make sense. Maybe he thought I’d not use anything that requires high amp. Anyway, I’m getting an 20A one after work today.Originally posted by Hillbilly View PostYou put the same in as came out other wise next time you may come out ot a pile of smoke and ashes
