Mk6 GTI EPC Fault - VCDS Scan Diagnosis
  • Mk6 GTI EPC Fault - VCDS Scan Diagnosis
    Hi Everyone,
    My 2011 Mk6 GTI developed a dreaded dreaded ECP fault yesterday.
    I performed a VCDS Scan today which follows.
    I have an idea what the issue is but would appreciate some feed back from the forum membership.
    Can somebody please diagnose my problem?
    Chassis Type: 1K (7N0)
    Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 55 56 62 72 77
    VIN: WVWZZZ1KZBW****** Mileage: 103470km-64293miles
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (CCZ) Labels: 06J-907-115-CCZ.clb
    Part No SW: 5K0 907 115 HW: 1K0 907 115 AA
    Component: 2.0l R4/4V TFSI 0050
    Revision: AAH18--- Serial number:
    Coding: 0403000C18070160
    Shop #: WSC 01357 011 00200
    VCID: 67F36E7E56A3D87948-8032
    4 Faults Found:
    001089 - EVAP Emission Control Sys
    P0441 - 000 - Incorrect Flow - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 21
    Reset counter: 255
    Mileage: 102177 km
    Time Indication: 0
    Date: 2011.07.21
    Time: 17:05:50
    Freeze Frame:
    RPM: 838 /min
    Load: 24.3 %
    Speed: 0.0 km/h
    Temperature: 99.0°C
    Temperature: 53.0°C
    Absolute Pres.: 1020.0 mbar
    Voltage: 13.843 V
    012425 - Signal Line for Fuel Pump Electronics
    P3089 - 000 - Electrical Malfunction - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 21
    Reset counter: 255
    Mileage: 102177 km
    Time Indication: 0
    Date: 2011.07.21
    Time: 17:05:50
    008504 - Accelerator Position Sensors (G79) / (G185)
    P2138 - 000 - Implausible Correlation - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 103455 km
    Time Indication: 0
    Date: 2011.08.20
    Time: 07:14:42
    Freeze Frame:
    RPM: 2839 /min
    Load: 40.4 %
    Speed: 76.0 km/h
    Temperature: 96.0°C
    Temperature: 27.0°C
    Absolute Pres.: 1000.0 mbar
    Voltage: 14.224 V
    008482 - Accelerator Position Sensor (G79)
    P2122 - 000 - Signal too Low - Intermittent - MIL ON
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 103455 km
    Time Indication: 0
    Date: 2011.08.20
    Time: 07:14:42
    Readiness: 0000 0000
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
    Component: ESP MK60EC1 H31 0108
    Revision: 00H31001
    Coding: 163B600D092200FB680B06E6901D0081350800
    VCID: 76CD333AC10931F1C3-8022
    1 Fault Found:
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 113
    Mileage: 103400 km
    Time Indication: 0
    Date: 2011.08.19
    Time: 07:31:17
    Freeze Frame:
    Count: 0
    Count: 32768
    Count: 4608
    Count: 8196
    Count: 49920
    Count: 0
    Count: 65280
    Count: 0
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 1K0 937 087 J HW: 1K0 937 087 J
    Component: BCM PQ35 H 103 0615
    Revision: 00103 AE
    Coding: 4A180A3A8037F1C040080080340009E441550488736D8D60E4 8000240040
    VCID: 3851FD028B9D878111-806C
    Subsystem 1 - Part No: 5K2 955 119
    Component: Wischer 09031 26 0512
    Coding: 009795
    Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 060411 05 54 0403
    Coding: 0330AD
    Subsystem 3 - Part No: 1K8 951 171
    Component: DWA-Sensor 00 001 0104
    Subsystem 4 - Part No: 1K8 951 605 B
    Component: LIN BACKUP HO H11 9005
    1 Fault Found:
    00061 - Footwell Lights
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 5
    Fault Frequency: 254
    Reset counter: 113
    Mileage: 91276 km
    Time Indication: 0
    Date: 2016.07.14
    Time: 15:37:12
    Freeze Frame:
    Term 15 On
    Voltage: 11.10 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    MY11.5 MKVI Volkswagen Golf GTI | 5 DR | Deep Black Pearl | Manual | Bi-Xenons (Incl LED's) | 18" Detroits | Black Leather Package | RNS510 Sat Nav | MDI | Bluetooth | R Tails | P3 Gauge
