Hi guys
I have replaced my 1K0 970 530 E CAN gateway with a 7N0 970 530L to try and stop the battery drain from the RCD510; however, I am still getting a slow drain. After one week the car takes a while to start, after two weeks the battery is dead.
I am trying to find out if it is incorrect coding on my behalf. I have one constant malfunction, that is Module 61: Battery Regulator. I don't have a battery regulator and so i UNTICKED it in the installation list; however, it is still showing up in the Auto-Scan. How do I code it out totally so that it no longer shows up in the Auto-Scan.
Is it possible that the CAN gateway is not going to sleep because it is looking for this battery regulator module thats not there? How can I code it out of the Auto-Scan....?? - As you can see below, its in the auto-scan list at the top, but then does not show up in the actual scan.
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 A HW: 5K0 035 190 A
Component: Radio RCD510 051 0207
Revision: 00000001 Serial number: VWZ1Z3L8071483
Coding: 0101000001000E
Shop #: WSC 00020 790 12345
VCID: 236B327C22383306A65-8076
No fault code found.
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 C
Component: Tuersteuergeraet 06 0213
Coding: 0000016
Shop #: WSC 00046 412 00000
VCID: 3041CD30A3CE989E2B7-8065
Thanks!!!
Remi
Coding: 0000016
Thanks!!!
Remi
