I own a Passat Variant B7 from December 2012 and I would like to activate Tire Pressure Monitoring System via ABS (4C), but I cannot find any information about how to code my ABS module type: 3AA 614 109 AF to enable this.
The current value is 0000378. According to VCDS I should add +1024 to the value for TPMS (PR-7K6), however value 0001402 is not accepted. (“Out of Range”)
I was able to read the values of another B7 Passat which has TPMS. The ABS module of this Passat is type 3AA 614 109 AC and the coding is 0001414. But my Passat has autoparking which also requires a setting in the ABS module.
Does anyone know which coding I should use to enable TPMS on my Passat?
