Has anyone reset their DSG using VCDS?
DSG Reset
DSG Reset
Tags: None
You're a big help Ryan. Was that on a DQ500 or 250?Originally posted by Ryan_R View PostYes
Ross-tech have one for the 250 but they don't say if the same procedure works on the 500.
Perhaps I should have been a little more specific. Yes Dq500 gearbox and resetting the fuzzy brains back to zero.
Originally posted by lankfert View PostI have done it on my MK5 GTI. Took about 5 mins. Gearbox jolts around a bit, clunks etc. Also did throttle body alignment, made no difference to the way the car drives.
I just followed the procedure off Ross-Tech website.
Thats for the DQ250 which may or not be the same procedure?
I've got an injured hand and don't want to type more than necessary.Originally posted by h100vw View PostYou're a big help Ryan. Was that on a DQ500 or 250?
Have a look here: http://www.vwwatercooled.com/forums/...tml#post572595
Good lad!
just need to get Ross-tech to write it up in VCDS speak.
Originally posted by Ryan_R View PostI've got an injured hand and don't want to type more than necessary.
Yeah though I'm 99.9% sure those instructions are for DQ200 7 speed dry clutch DSG used in Golf.Originally posted by h100vw View PostGood lad!
I'm looking for instructions for DQ500 7 speed wet clutch as used in Tiguan, Transporter and Audi TTRS.
