Installing used ECM Immob 3
  • Installing used ECM Immob 3
    Any extra info would be great if anyone has come across similar issue
    Long story short i need to adapt a used ECM to a vehicle. I've read that the pin is required for the used ECM not the original pin. How can this be extracted or found out? Has anyone come across this issue. Any extra info would be great. Cheers.
    What vehicle? What year?
      Hi transporter, 2005 t5 Immob 3 I have the pin from the original ECM but going of what is written on Ross tech web page I need the pin from new used ECM which I can't access have you had this issue. Cheers for your reply.
        Re: Installing used ECM Immob 3
        The companies who repair the ECUs can help you. The Autologic can read it as well, but I'm not sure how easy or difficult would that be when the ECU is out of the original vehicle.
        Sent from my GT-N8000
          Cheers for your help mate I've ended up taking to dealership for adaption. I've learnt something regarding used ECM swapping.
            Yep, Immobiliser III-onwards is adapted to the ECU.
            The dealer will obtain authorisation online from Germany to do it.
