Hey guys,
Purchased a second R36 Passat with what I believe a factory RNS510 with satnav. Original problem I had was that the fader control did not appear. This did appear once I coded it correctly. Now I get the below fault codes. Tried changing active speaker settings with no luck, even tried Dynaudio setting with no change. Brings me to my next question, how can you tell whether car has the dynaudio system? Please see scan results below.
cheers,
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 A HW: 1T0 035 680 A
Component: RNS-MID H05 1020
Revision: AB001001 Serial number: VWZ6Z7H7288092
Coding: 000100000100000000
Shop #: WSC 00000 000 00000
ASAM Dataset: ------------------------- ------
VCID: 2C5D1F81F69B
1 Fault Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 115
Mileage: 39584 km
Time Indication: 0
Date: 2011.09.09
Time: 20:20:55
Address 47: Sound System Labels: 3C0-035-456.lbl
Part No SW: 3C0 035 456 K HW: 3C0 035 456 K
Component: 08K Audioverst. 0001
Revision: 00001000 Serial number: 00000000180207
VCID: 2855E391E263
No fault code found.
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
VCID: 2C5D1F81F69B
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 115
Mileage: 39584 km
Time Indication: 0
Date: 2011.09.09
Time: 20:20:55
cheers,
VCID: 2C5D1F81F69B
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 115
Mileage: 39584 km
Time Indication: 0
Date: 2011.09.09
Time: 20:20:55
VCID: 2855E391E263
VCID: 2C5D1F81F69B
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 115
Mileage: 39584 km
Time Indication: 0
Date: 2011.09.09
Time: 20:20:55
