VCDS label file for GT TDI engine, BMN 125kW/170PS
  • VCDS label file for GT TDI engine, BMN 125kW/170PS
    Created from German VCDS label file and merged some details/translations from English BKD file.
    Some translations are iffy (thanks Google Translator), use at own risk.
    Put this file in C:\Ross-Tech\VCDS\Labels\User (right click, save as)
    03G-906-018-BMN.lbl
    Should also work for:
    Audi A3 (8P) / Seat Altea/Toledo (5P) / Seat Leon (1P) / Skoda Octavia II (1Z) / VW Golf V (1K) / VW Passat (3C) / VW Touran (1T)
    Component: J623 - Engine (#01) - BMN/BMR/BUY/BUZ 2.0l TDI-PPD 125kW/170PS
    Edit 29/03/2012:
    The latest version of VCDS now includes a label file for the BMN engine!
    Golf GT Sport TDI
    Wow that's awesome.
    Now pretend that I have not spent much time getting my head around Vag Com, not much past a few basic logs and removing error codes, and forcing a lot of regens!
    What can you do with this mate???
    I'm keen to follow your lead and reset my pressure sensor, be nice to have my car back to loading regens rather than the kms it seems to be set on now.....and the regens are odd too.....
    Guess I could always actually READ the instructions....
      Originally posted by Greg Roles View Post
      Wow that's awesome.
      Label file pretty much describes what this is, it is simply the labels of all the different measuring block values and documents the adaptations and codings.
      Now when you go into measuring blocks and advanced measuring blocks you will be able to see a list of (more) meaningful values. Most useful of which are the DPF measuring blocks which are not documented in any of the existing English label files as far as I can see.
      Coding (I) is now corrected so it makes sense for our cars, Coding (II) now documents cruise control enable/disable, Forced DPF regen, and exhaust pressure sensor adaptation.
      Adaptation now contains:
      Starting Torque Compensation
      Torque Limit
      Generator load balance (guessing the correct translation here should actually be alternator)
      Servo pump load balancing
      EGR (this may be interesting, we might be able to adjust the EGR so it doesn't come on as much)
      Idle Speed
      Maximum speed limit
      Coolant temperature adjustment
      Air compressor torque compensation
      Ash mass balance
      Injectors 1,2,3,4
      Whereas the BKD file only contains adaptations for the imobiliser.
      Golf GT Sport TDI
        Oh yeah and to adapt your new sensor this is what you do (look at Coding II section of file)
        Go into Coding II
        Enter 30605 (top box)
        Press "Do it"
        Should say accepted code or something like that.
        Note: After adjusting the differential pressure sensor or
        activate / deactivate the cruise control system
        Turn off the ignition for at least 30 seconds OFF!
        Golf GT Sport TDI
          Thanks man, that's brilliant, I understand!
          Will have a major play, and any way to turn down the EGR is a good thing, doesn't really apply to me anymore though : )
          Great thing you have done for the PD170 community mate, well done!!
            Epic Win Jarred.
            I'm doing this, tonight-ah!
              Wow
              LOADS of new info.
              Under advanced measuring values it said my ash rating was 36.7g out of a maximum of 60.
              Does that mean my DPF is only half full? Sweet action if so, especially at 115,000km.
                Originally posted by benough View Post
                Wow
                LOADS of new info.
                I guess so, the 60g value comes straight out of the German file. I guess they got it from a technical bulletin or something like that. Mine is at about 17g with 100,000km.
                Golf GT Sport TDI
                  Well maybe it's a value before the regen then. 60mg is a tiny number.
                    Care to shed any light on the potential EGR adaptation Greg?
                    The value VCDS gave me last night on the flap seemed to be a maximum of 50% (shut I presume)
                      I think there is a difference between soot and ash. The soot comes up as a % load. I think a small amount of ash is left in the DPF after the soot is burnt off. Will need to verify this though, I might just be making it up.
                      0% is no EGR.
                      Golf GT Sport TDI
                        Soot is the % difference between the pressure sensors that is burnt off.
                        Ash is the amount of extra blockage compared to new, so yes, you want lower ash values.
                        Haven't had a chance to play with this new Jarred-Tec yet, been slammed at work and busy with Carformance, few new companies coming onboard, and two major diesel ones!
                        Will have a look at the EGR thing over the next few days, but the less you can have it operating, the better, mine is hanging in the breeze, and the car is running GREAT.....
                          Well I drive mine "well" and travel on motorways daily.
                          So what values should I be setting the EGR to? Lower or higher?
                            I think higher. I would be reading around a lot before changing it though, it may cause a engine light (found people talking about this on Mk4s).
                            From what I've seen you may need to enter a login code before you can change it anyway.
                            Golf GT Sport TDI
                              I know with the MK4 on TDI club you enter some number that is an unachievable value for EGR, and it basically never comes on - has been something I've wanted to do to the GT for years now....Ben I reckon you should set it to lower, you want a low % EGR! What I can do is compare my exposed EGR flap to the VCDS readings now - stay tuned!
                              My Ash is 25g, played with it on the way home. Less than half full, which amazes me actually considering the torture I've put it through!
                              Just awesome Jarred, owe you one, looking forward to a lot of playing on the weekend!!
