Only got my Bi-xenons turned off as DRL at the dealer. Dunno what he did...
Mk6 GTI VCDS ( VAG-COM ) codes
It's interesting that some say it can be done and some can't. My dealer spoke with VWA (probably their first mistake there) and were told it can't be done.Originally posted by MkVIGTI View PostOnly got my Bi-xenons turned off as DRL at the dealer. Dunno what he did...
I was also told the static cornering lights can't be turned on with bi-xenons either.GTI | Carbon | Man | 5 door | Leather | 18" Detroit | Bluetooth | MDI | Bi-Xenon
I enabled the Static Cornering Lights with Fog Lights on my GTI today. Took a little while to find; I believe it's the bottom-most tickbox for byte 14 in the long coding helper.Originally posted by bjays76gti View PostI had my Mk6 GTI in for coding changes today, the tech had an issue with trying to activate the 'static turning lights' After you access the long coding helper on VCDS, which is the exact byte to change? to be able to bring up the check box to activate? Is this thats all thats required?
Interestingly, the relevant fog light comes on when I turn on my indicator as well (as long as it's below the requisite 40km/h or whatever the speed threshold is). According to the VWVortex thread this may be controlled by byte 17, but I didn't touch that, so was a little surprised when I noticed it enabled.2008 MkV Volkswagen Golf R32 DSG
Hey guys I don't know if any of you are experiencing this..
I tried to use Vagcom to access the bytes for cornering fog lights, DRLs, Needle sweeping on ignition and rear led lights.
The only one that worked was for the LED rear light error correction.
The other setting came up with short coding unlike the normal ones (long code). Therefore, when trying to correct byte 17 or 18, nothing is there.
I don't know if this all makes sense but can anyone help?
Mine is a 2010 build and bi-xenon.
Sounds to me like your looking in the wrong controller if you are that short of bytes. I am guessing you should be in the long coded "Cent. Elect." and you are looking at the short coded "instruments" instead.Golf Mk6 118 TSI DSG |APR Stage I ECU Upgrade | HEX-USB+CAN
Yeah you probably were, but to correct my previous.... Instruments are actually also long coded but only have 3 bytes so relatively speaking they are short. so if you were to wander in there my mistake and open LC helper, you will just be seeing 3 boxes full of hex instead of the 30 or so in "Cent. Elect." where you should be looking. Even my 118TSI has bytes 17 and 18 full of all the check boxes for static cornering and light related stuff for GTIs. That would be my guess. You were looking in the wrong control module if you could not find those bytes. Beyond that, I do not have a GTI, so I will defer to someone who does.Golf Mk6 118 TSI DSG |APR Stage I ECU Upgrade | HEX-USB+CAN
Everything bar Staging (sweeping needles) is done in Cetral Electrics (09) -> Long Coding Helper.Originally posted by moonblade87 View PostI tried to use Vagcom to access the bytes for cornering fog lights, DRLs, Needle sweeping on ignition and rear led lights.
Static Cornering Lights (see also byte 17 to disable cornering lights on indicator)
Staging
Not sure about the specifics of disabling the DRLs for Xenon-equipped cars, sorry!2008 MkV Volkswagen Golf R32 DSG
Emergency Stop Inicator Flashing
Originally posted by STV4SYT View PostHaha, i did that today, gonna try it at 4 flashes and see how it goes.
turned on emergency braking lights too, havent tried it yet and hope i never have to.
Hey - turned on the emergency stop indicators with VCDS & tried it out - seems to only work with very severe application of the brakes (initiate ABS). On the Skoda there is option to flash the indicators or the brake lights.Redline3345 MY11 Octavia vRS Wagon TSI DSG | Brilliant Silver | Milltek cat back exhaust | Bilstein PSS10 | TSR Panorama | Remsa | Leather | Sunroof | Towbar | Front Sensors | Boot Protector | Xenons | Corner Fogs | Alarm | Extended Warranty | Superskoda Bits & Bling
