Hey guys, has anyone been able to enable traffic sign recognition in an MIB3 system?
The following doesn't work as some of the adaptations and coding have changed (highlighted in red)
Enable Dynamic Road Sign Display
- Go into Module 5F Information Electronics
- Select Adaptations, then Vehicle_Functions_List_BAP_Gen2
- Select menu_display_road_sign_identification_0x21, and set to Enabled
- Select Adaptions, Vehicle_Function_Adaptations_Gen2-menu
- Select menu_display_road_sign_identification, set to Enabled
- Select Coding, and then select Byte 24, activate Bit 6
- Go into Module A5 - Front Sensor Driver Assistance
- Select Coding, and then select Byte 16, activate Bit 4
- Go into Module 17 Instruments
- Select Coding, then Byte 5, active bit 2
- Go back into Module A5 - Front Sensor Driver Assistance
- Select Adaptations, then Road sign detection fusion mode, and change to Road Sign Detection. The original is Road Sign Fusion
- Reboot the infotainment unit
