OBDeleven blocked
  • OBDeleven blocked
    Santa gave a friend of mine an OBDeleven dongle for Xmas.
    How does s/he (the friend) download the softwares ?
    All I can find is this message on the Voltas IT website.
    Voltas IT Support
    Current : 2017 Mk7 Golf R (most options) || 2012 Golf Mk6 TDi (few options)
    Gone : 2004 Bora V6 4Motion (few klms, all options)
    Once you get the software, the security settings on the phone/tablet need to be changed to allow an install from unknown sources. If you have any trouble getting the software let me know - I can dropbox it.
    Indium Grey Golf 7.5 Alltrack 135tdi Premium - all options
      Open on your android device and allow to install from unknown source App
        I just updated my obdeleven software after a long time of not being used.
        Made some notes to help next time/s. Hope these short notes help others too.
        There's sure to be a way to adapt this for Windoze and/or OSX.
        Using a Linux host, download the latest apk from
        Must have package android-tools installed (RHEL, CentOS, etc)
        Enable the Android (eg OnePlus) device in following file on Linux host :
        /etc/udev/rules.d/51-android-rules
        use dmesg for the vendor and device ID's
        Example usb 2-1.1: New USB device found, idVendor=2a70, idProduct=f003
        Setup the adb connector on Linux host
        /root/.android/adb_usb.ini
        eg 0x2a70 as above
        Connect the phone using usb cable
        Enable usb debugging in Settings, System, Developer options
        uninstall the old obdeleven version from the phone, else the install below will fail
        From the Linux host
        # adb kill-server
        # adb start-server
        # adb devices -l (lowercase L, not numeric one)
        Make sure phone is listed
        Then
        # adb install OBDeleven.apk
        Wait while approx 25MB are transferred to phone.
        "Success" message when complete.
        Turn off usb debugging if desired.
          No need to do that any more at all and I never did all that in March when I got mine Simply typed the addy into the phone and it downloaded the APK
          HOWEVER as OBD ELEVEN is now legally licenced to use world wide except for China it is a simple download from the Playstore
          But as said you must allow other apps
          Have just installed it on a spare phone took about a minute and all working
            Mine wouldn't update via the Play store, so I used the legacy method above. It still works.
              Have you got unknown apps allowed as i used an old phone and its fine also on my S6
