Any one familiar with swapping a second hand ECU into the above? Have checked some re programming stuff on u tube and came across one which said if u swap the EEPROM from old to new ECU via de soldering and re soldering then re coding is not necessary, the Ecu was a edp15 Bosch model and mine is a Siemens model so was wondering if this can be done given the EEPROM stores immobiliser coding according to the video. Any info regards this appreciated cheers RON.
ECU swap 125kw Passat 08 model
