Where have people been buying their res delete pipes from and is it worth it sound wise?? I've been thinking of getting the Remus one but can't see too many others companies that sell it? Cheers!
Mk7 R Res Delete
A good exhaust place can just put you in a good quality pipe, rather than spending money on an actual pipe. Rob Bliss in Geebung Brisbane did an excellent job on mine and the noise is fantastic.
Sent from my iPhone using Tapatalk2015 Golf R. Lapiz Blue.
What did it set you back? Do you get any drone, I only want a bit more noise without is sounding obnoxious? I was thinking I liked the pre-made pipe as it is not welded and easier to revert back to stock if required.Originally posted by Reedy View PostA good exhaust place can just put you in a good quality pipe, rather than spending money on an actual pipe. Rob Bliss in Geebung Brisbane did an excellent job on mine and the noise is fantastic.
Funny you should say that. Rob Bliss made mine easy and to change. One side is bolted together and the other uses the sleeve. He the put a plate on the Resonator he took off so it could be bolted back in place. I think is was $150 all up. The noise is awesome, normal driving you would never know until you get in it the the car sounds like it should. I've coded my flaps to always stay open too. I like the drone but the kids sat in the back don't do I lines the spare wheel well with some sound deadening material, not sure if this helped. Over all drive normal and you would never know.
Link to a thread I started with pictures of what I had done.
Resonator Delete Options
$150 makes sense to use them as the Remus pipe is $185 and then I would still need to fit it. Great idea to fit out the existing res to be able to be used later. I'll mention that to them and they might remember your install! I've tried the exhaust flaps permanently open for a month or so but found the drone too much. Between 1500 to 2000rpm felt like my ear drums would pop and thats where the car seems to sit when in traffic. It does sound much better at idle though.Originally posted by Reedy View PostFunny you should say that. Rob Bliss made mine easy and to change. One side is bolted together and the other uses the sleeve. He the put a plate on the Resonator he took off so it could be bolted back in place. I think is was $150 all up. The noise is awesome, normal driving you would never know until you get in it the the car sounds like it should. I've coded my flaps to always stay open too. I like the drone but the kids sat in the back don't do I lines the spare wheel well with some sound deadening material, not sure if this helped. Over all drive normal and you would never know.
Got mine done on Friday at Rob Bliss. Very happy with the results for such a small outlay. Awesome mod for such little money. I'm surprised at how much louder it is when the exhaust flaps are open. The DSG crack on gear changes is impressive as well and no drone. Should be like this from the factory!Originally posted by Reedy View PostYes Rob Bliss was very good and he's done many of these. Took him about an hour.
