GroundControl may have what you're looking for if you just want to go off-the-shelf. I don't know much about camber plates and how they work so I'm afraid I can just point you to one direction!
I'm using KW camber plates on the R32 they do camber & castor though I am unsure if they make them for the Mk1 check with Dragan at Inmotive. As mentioned above Ground Control also make them and they are good quality and used extensively on various other R's from the states. Do a search on Vortex for Ground Control Camber Plates as I'm pretty sure the manufacturer is a regular poster on the site.
