G-8VXWWTRHPN Race Car Steering - VWWatercooled Australia
Race Car Steering
  • Race Car Steering
    is there any kits out there to have full locked wheels while turning the steering wheel under 360 degrees?
    wabit
    1 turn lock to lock is pretty scary. I've seen it done using the hydraulic steering head off a forklift, this was on a sprint car though.
    Qaife make a quick rack conversion - 2.9 turns lock to lock.
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
      wabit
      Umm it's a car not a Playstation!
      LOL you need a MADCATZ steering setup for your Golf!
      Pete
      7? MK1 Caddy
      12 Amarok
        the clubgti forum was going a mk1 quickrack group buy
        Velly
        '91 2.0 8v GTI
        Originally posted by DubSteve
          Go drive a race car on the road and see if you still want a quicker steering ratio, especially non-assisted...
            How 'bout this one ? I think they're 270degrees lock to lock.
            7? MK1 Caddy
            12 Amarok
              why.. what are the pro's and cons??
              sorry for the silly questions but its for good measure
              wabit
                This is what we used to use on our beetles set up for motorkhana's - never needed anything for the track!
                  i'm confused why would you want more sensitive steering for higher speeds? i mean maybe slightly for the tight corners but sheesh full lock 1 turn? you'll be fishtailing all over the place wont you lol?
                  2x Caddy, 1x Ducato
                    Race cars don't have a lot of lock to begin with(ie you'd have to do a million point turn if you had to do a u turn). So a quick rack and reducing the amount the wheel can turn would give you the same feeling
                    mk2 GTi 16v
                    Corrado G60
                      The fewer turns the heavier the steering will be.
                      With only one turn lock to lock you'd need to be Superman to park it.
                      Obviously the intent is to get the car to react quicker but there's a lot of trade offs.
                      Remember that the steering wheel works in both directions. Every bump, pothole, gutter, pensioner etc that you hit is transmitted back through the wheel. On a stock rack the sensation is geared down quite a lot so it's not too bad at the wheel.
                      With a quick rack you're not only reducing the movement required to turn the wheel you're also increasing the effect at the wheel of the road bumps.
                      So if you halve the number of turns lock to lock you DOUBLE the "road feel" back through the wheel. On a long drive the wheel will beat your arms to jelly.(Especially on a lowered car with stiff suspension)
                      Going from stock to 1 turn the ratio is probably something like 3.5 times.
                      The effect this has on the driver is very tiring , you'll be fighting the thing constantly. There will be no more steering with one hand while you're changing radio stations. One inch on the steering wheel now means you're under the front of the oncoming Kenworth.
                      For racing the goal is to not have to take your hands off the wheel for any corner of the track so some reduction form stock is required. If you reduce it too far though you loose the very fine control and are at risk of overdriving the car. There's a limit to how fast the car can accept input. On a stock car it's set up with a fair safety margin so that rapid input changes are not possible and the driver is not fatigued by road noise transmitted back up the column.
                      Motorkhanas are a special case, you do want to go very fast from lock to lock but they're usually held on loose surfaces. You're also only out the in the dust for 30 seconds at a time.
                      The sprint car example I mentioned earlier is also a special case, those guys are insane and there's no logic that can be applied to what they do.
                      To get down to one turn lock to lock you'd probably need to go to fully hydraulic steering which isn't practical for soooo many reasons but if you've got a bucket of money and you're considering a career as a sprint car driver I can give you a few tips on how to set it up.
                      Pete
                      7? MK1 Caddy
                      12 Amarok
                        Driving a go-cart for more then 30min isnt easy. Your forarm is left a bit bigger and numb after it and hands red from griping the wheel.
                        Would be similar, true?
                        MK1 GLS 3door
                        A4 B7 2.0T
                          Probably worse because you're going faster in a heavier car.
                          Pete
                          7? MK1 Caddy
                          12 Amarok
                            pete you're a funny man.
                            go play playstation witha steering wheel and set up the wheel to have really small dead zones, this makes it quick to respond. and trust me, VERY difficult to drive!
                            I can see where you're going. maybe look for a "racing" (I use this term loosley) spec rack. I expect this would be V.expensive, and hard to find in OZ
                              Pete
                              The faster you go the lighter the steering becomes because the friction against the road begins to assist you as you turn instead of work against you.
                              The main reason karts have heavy steering is because they have 14deg (average, i have seen some with 1 caster angle, which is far greater than a road car.
                              But yes, because the car is substantially heavier, it would be worse. And the car with a closer to 1:1 steering ratio would be ridiculously nervous on the road. You'd be weaving your way up the street just trying to keep it straight!
