Browsing a tuning thread on another forum for the new Audi S3 (equivalent to Mk7 Golf R) someone posted some written communication from ABT:
Sounds like the additional hardware and R&D will likely increase the costs of these software tunes.
Info on the current TD1 warranty flags:
On some newer cars ECU modifications are automatically detected when connected to diagnostic equipment and recorded on the VAG servers for life. On older cars the technician has to run a time-consuming scan process to check - some technicians won't bother wasting time doing this if they don't have to.
Reference tuning, as discussed this is something we can offer, this would be in the form of an ABT AEC (ABT Engine Controller).
This is an additional ECU which runs along side the Audi Module to increase power to 370PS! Torque is also up by 80NM.
The huge advantage of is that is untraceable via the new Audi diagnostic tool as it is a totally separate engine control unit with a different address.
Reference removal, It is visible in the engine bay, however it is not visible to the Audi Diagnostic tooling.
The main issue reference warranty claims seems to be where the car goes online to Audi, (when a conventional remap has been carried out) it then logs the fact that the ECU has been re-programmed and then can cause issues reference a warranty claim. As this is a separate module that does not occur as it has no way of communication via the Audi tooling.
So in summary it could be removed if required, however no really necessary. - We can also offer a 'bridge' device that simply plugs in so the fitted loom to return the car to standard.
