engine pinging
    go the premium... always.. normal is shizaaaaa!!!!!
    wabit
      Awsome, im putin a tank in next fill up.. cant wait to see the difference :twisted:
        I dont recomend caltex premium , seems to ping on my lower powered cars . My more powerful cars get fed 98 BP Shell or Mobil .
          i had some problerms with my central locking, it just did'nt work one day. it turned out to be a very simple problerm that was caused by corosion on the wire terminals at he pump which is situated next to the passenger side rear tail light in a foam casing.
          turned out to be a very simple problerm, the kind i like, ya do get them sometimes, i hope it is easy as that for you
            Imagine the trouble we have in Tas we can't buy 98 at the pump and I'm told Vortex is the best of a bad bumch over here.
              If you cant buy 98 then I wouldnt be trying to gain much from the engine . If you decide to run 95 + octane boost be prepared to change plugs more often . If you need 98 use toulene to suppress pinging and run 95
                im just wondering has anyone tryed the 100 octain that shell has?? is it any better than 98??
                  no point . Late cars you cant change ignition timing to benefit from extra octane , stick to 98
