Finally got the Bluefin from Superchips NZ. First impressions very good. The only issue I had was the cdrom software that came with it wouldn’t load onto my computer so I just downloaded it from the mybluefin website, turned out to be very easy. Taking my ecu data from my car with the device took less than 5 minutes and putting the new remap on the same. Very easy to do and clear instructions, you can’t get in wrong.
Now for the driving. Not been for a long drive or even seen what it can do, just a steady drive to work this morning but can straight away tell there is something special waiting to happen. You don’t have to push the accelerator as far down to make it go, which may help use less fuel?
Two things that do concern me a little is the flat spot has now moved from 1800 rpm to 3500, it is like having 2 boosts, plenty of power from stand still to 3500 rpm a little pause and then away you go again. I emailed superchips straight away and they replied straight away saying give it the weekend to learn the new values and if it does not improve let them know.
The second which is a little worrying maybe is the water temperature reaches 90 very quickly, Any body else noticed this? It doesn’t get any hotter it just gets there quicker. Any thoughts.
Forgot to mention the new remap arrived back within 10 minutes last night.
