Just installed awe tuning intake on the mk6. When I start the car, it starts then the idle goes crazy... Up and down ... Really rough... What can be wrong? I tried vagcom, no fault codes
Cars idle goes crazy after intake install
Check that the MAF is not backwards. When you pull it out you can see the window that the air needs to enter into. US spec GTIs have the orientation of the screws reversed.
If thats ok check that you dont have any leaks.
FOLLOW US ON FACEBOOK
what if you drive in reverse ?
Sounds plausible; the exhaust becomes the intake and vice versa.Originally posted by parso_rex View Postwhat if you drive in reverse ?
=)VWWC Members - 2018 Special - ECU & DSG Remaps
DNA Tuning Australia - Enquiries: info@dnatuning.com.au
My diesel won't pass 2,500rpm unless the clutch is nearly out and its in gear... Its a TC thing (and launch control? yay!)Originally posted by alphabeatsco View PostWeird question... Is it normal that the car can't pass 4000rpm when it's in neutral and parked?2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
Not including hers...
