So I want to try something new as a project and I've done some research and just gonna run it through you guys to see if it's possible.
Planning on removing the stock TD02 (03C145702C) turbo from the 90TSi engine and swapping it with a K03 (06A145704). From what I can see, the only main difference between them is the divertor valve isn't located on the turbo, the flanges are different but the oil lines and position of the turbo is very similar.
Will need to fab a new dump pipe, manifold and intake pipe to fit the DV to.
Has anyone attempted this? or started too? Very interested to find out as much as I can before I start buying turbo's and getting pipes and manifolds made.
