Just wondering if anyone can recommend a Standalone Engine Management system that is really easy to set up and use in a mk1 Golf with 1.8t?
Does anyone have any experience with Lugtronics? ive found they have a fairly plug and play kind of system and would be keen to use it if its a s good as it sounds. From the way the describe it its just an ECU that plugs into the stock harnes with an adapter, you just have to run a vacuum line to the ecu which has a MAP sender in it.
Would local tuners be able to change the maps and generally be able to tune it?
I have no idea about SEMs!
please guide me!
Thanks!
-Steve
please guide me!
Thanks!
-Steve
