High pressure boost gauge?
  • High pressure boost gauge?
    Not sure if it belongs in this section but couldn't figure any better place
    Does anyone know of a high pressure boost gauge? All the ones that I'm finding only read up to 30psi.
    Resident grumpy old fart
    sounds like you need a train steam pressure gauge!
    My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
      need some specs on the gauge and may be able to help out..
      what size gauge (diameter etc)
      electrice or mechanical??
      what pressure ?
      specific style of gauge or anything???
      There are heaps of gauge manufacturers out there...
      1974 1300 Beetle, 1997 Golf GL, 2003 New Beetle Cabrio, 2014 Audi A4 quattro
        what pressure ?
        Auto Meter Ultra-Lite Analog Gauges 4305 - SummitRacing.com
        Summit Racing do lots of stuff, find what you want then check google I reckon.
          Thanks gavin - the ones I found were all over US$200
          I should have added the word 'affordable' my OP since the 30 psi gauges are far less than that.
            Speedhut have nice electronic gauges - in range of diam and pressures psi and bar.
            Fullly customisable to suit you tastes.
            Boost range: Gauges - Speedhut
            They also do 0-60psi
            I'm very happy with them.
              I know I've seen this done but is there any way to get boost pressure in MFD apart from buying a kufatec BT unit?
              - Tigger73's 125TSI Build
