G-8VXWWTRHPN 4 bar FPR - VWWatercooled Australia
4 bar FPR
  • 4 bar FPR
    Hi,
    I have got a polo gti 9n3, and am completing a few mods...ok more than just a few.
    My question is that I need to get a new 4 bar FPR, and I am sure a lot of you have already done this, so what would you suggest..it would be great if you could give me some part numbers nad makes/ models..and even beter where I can get this from...appreciate you asistance.
    Polo 9n3 GTI
    Hey mate Bosch do a drop in 4 bar reg for your OEM fuel rail. Only about $50 or so and 10 min DIY. I'm running one with no probs.
      With the 4 bar reg you will only see real benefit if you are going to run a bigger pump and injectors, some say better atomisation with the fuel rail having 1 bar more pressure.My opinion is the injectors will only spray the amount designed and for however long the ECU decides they must. Id be keen to hear more as ill be looking into similar mods with my 6N2 harpoon.
      Jmac
      Alba European
        thanks vwindahouse...just btw do you have a part number, or did you just ask fire a 4 bar fpr for any 1.8 turbo vw
        Polo 9n3 GTI
          Sorry forgot that part, it's the same one for the MK4 Golf GTI
          Volkswagen Golf IV 1.8T > Engine > Fuel > ES&#35;1073 Bosch OEM 4.0 Bar Fuel Pressure Regulator - 0280160575SJ
          And I know youv'e mentioned you're doing some major upgrades soon. Just wondering what you have in mind You really won't need the reg unless you're adding more air flow and boost to the equation.
            Thank you... am looking a tryng to get as much power out of the litte polo as possible whist still being a road car I love these little Polos, as I a sure you do. I have had polo's, since the first was released over a decade ago. So what I am doing is, remaping ECU (APR), sorting out intake (BC/carbonio), 3" down pipe ...debating about the exhaust, as I dont want to much noise, and the polo exhaust is not bad. New larger intercooler , FK highsport coilovers .......
            and finally:
            1. Puting in a "beter" turbo ---T4 (have not done this yet) , and ths is why I am sowly buying parts for the car to get it T4 ready (FPR,
            3" MAF etc..).
            2. Putting in bigger calipers and disks
            Also keep on making the polo more pretty, beter mags, badges etc.....
            Polo 9n3 GTI
              If you are stuck the Passat BBG V6 runs a 4.0 bar reg standard if you are looking for one. Plenty V6 engines in the Euor wreckers these days
              Jmac
              Alba European
