G-8VXWWTRHPN steinbauer chip - polo 77tsi - VWWatercooled Australia
  • steinbauer chip - polo 77tsi
    hi, i was just wondering if anyone has experimented with a steinbauer chip in a 77tsi.
    the power gains are looking quite impressive.
    thanks
    Some details ?
    POLO 77TSI DSG 5D - MY11 - REFLEX SILVER - COMFORT PACK
    Engine - K&N Air Filter (e-2997)
    AV - Rockford Fosgate T1652-S , T1652 and P3L-S12 Sub. Alpine MRP-F600 and Alpine MRP-M500, Dynamat
    Planned - lots, but the "financial manager" says NO
      power gains:
      before, 77kw - 105ps - 175nm
      after, 92kw - 125ps, 210nm
      for $2392.. abit dear?
      STEINBAUER Tuning Technologies
        Very dear for a unit that needs to be hooked into the following sensors:
        Boost Pressure sensor pre throttle control valve
        Boost pressure sensor post throttle control valve
        Camshaft sensor
        Turbo control valve
        Coolant temperature sensor
        For close to $3k, i'd be wanting something damn special for that, like an intercooler and exhaust as well.
        Oh, you also need to adjust the potentiometer in case something isn't quite running too well as the unit can provide too much power etc(?!?!)
          Like most piggybacks, it only alters the fuel map so boost remains as stock.
          I'm sure Vinnie got very similar (or better) improvement with a DNA Tuning remap (based in Melbourne!) for well under $1000. Contact DNA Tuning (John Lu - top bloke) - they are a site sponsor.
          Resident grumpy old fart
            $2400....that is daylight robbery. Go to DNA tuning for less than a $1000
              ABT will take the 77TSI to 103KW. Not sure of the price tho'
              MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
              2008 GOLF .:R32/5DR DBPE DSG/SUNROOF/RNS510/PRIVACY TINT/CONTI SC3s/MILLTEK CATBACK NON-RES/9W2 BT/"MYR-032"
                lol... that's almost half way the difference to a Polo GTI! Yet the Polo GTI has much better features and even more Powah!
                What the above peeps said
                  FYI
                  Vinny7's impressions for DNA Tuning remap (no figures)
                  DNA Tuning power increase 77TSI: 77kW / 175Nm -> 100kW / 220Nm
                    According to their copy for the Polo GTI, they do mess with the boost levels, can't say about the 77TSI because I didn't actually look...
                      ADVANTAGES of the STEINBAUER Power Enhancement:
                      No active increase of boost or common rail pressure!
                        Thanks for recommending our tune. We do increase the boost levels, it doesn't make sense not to - it's turbocharged after all. We only increase the boost by 20%, and also focus heavily on ignition timing and slight alterations to the fueling.
                        Also, our upgrade is a proper ECU remap and not a piggyback; this allows us to carry out fine optimisations.
                        Also for $830, well... I would hope it's a no-brainer!
                        VWWC Members - 2018 Special - ECU & DSG Remaps
                        DNA Tuning Australia - Enquiries: info@dnatuning.com.au
                          Dammit kaanage, you're right! I didn't interpret what was in the instalation instructions correctly!
                          The STEINBAUER Power enhancement modifies the boost pressure and injection quantity by fine tuning the firing point and duration of the
                          injectors. This is achieved by blue printing and interpreting original electronic signals. These signals are recorded and recalculated to optimise
                          boost pressure, ignition timing, injection characteristics and the control of actuators to optimise performance.
                          To prevent the engine from damage the power enhancement starts from a certain engine temperature which is saved in the characteristic.
                          Furthermore the power enhancement is reduced or deactivated at the culmination of excessively high engine temperatures.
