Bigger injectors for GTI
  • Bigger injectors for GTI
    I have been searching for a while but with no luck so I thought I'd ask the question.
    I have been having problems with my 08 Polo GTI pinging under heavy load (FOOT TO FLOOR). I have a K04 Turbo, 2.5" manifold back system, 4bar FPR and APR K04 tune.
    I was thinking that under extreme thrashing the stock injectors can not flow enough fuel to supply the engine, therefore I may need bigger injectors.
    My question is what size are the stock injectors? does anyone know of a good upgrade? how much and where could I get them? and lastly is it an easy job to do yourself?
    Many thanks Pommie
    Have you thought about contacting APR and seeing what they recommend ? Would make sense to me.
    Also it would be worth finding someone with vagcom to run a scan and see what's going on.
      Or put it on a dyno to see what's going on. Measure injector duty cycle and AFR's and/or EGT to get a good understanding of what it's doing.
      Daily: 2010 VW Jetta Highline
        It could also be that the fuel pump can't keep up with the demand from the injection cycles.
        But I agree with DeanB - with that level of modification, you need to start looking at the logs to be certain what it going on.
        Resident grumpy old fart
          Log it. There are systems to reduce timing if the knock is too much, you should be able to see that in logging very easily.
          Def call APR as well.
            Injectors are plenty big enough for K04 - log as suggested above & make sure your fuel pump isn't on the way out.
              I dont know why some of the other tunes require different injectors eg OEM TT ones.
              Im guessing the tune is not as agressive as others which require more fuel.
              On saying that I am thinking of a K04 and seeing as I have the APR K03 tune, it is the cheapest option.
              Can you give us your thoughts on the K04, is it a genuine turbo, or something like a RP turbo ??
              MODS- TOO MANY
                Thanks for the replies, I'm now just waiting on APR to get back to the dealer. He said it may be worth re-flashing it as it seemed ok when it was first done, also to give it a scan and see what's going on. I'll let you know.
                As for the difference with the KO4, it is like chork and cheese from the K03 that had the APR tune. It's now a bit mental even in second it lights up the wheels - I would not want any more power... It is not a genuine K04.
                  Wow that is great to know, do you have a boost gauge in there?
                  I am seriously thiking of doing it
                  MODS- TOO MANY
                    for me it was the same difference as when I first got the std car APR tuned. Sorry no boost gauge.
                    The best thing was, the turbo cost about $400 from the States.
                      The software never changes in the car, it is fixed, so no use reprogramming it. What does change (in the fuel system) is
                      Fuel filters clog up & let less fuel through
                      Fuel Pumps can die (our own Polo GTI K04 had this issue & it took us weeks to work it out)
                      Injectors can become dirty and / or blocked
                      Thats why its important to log data to try to find the exact cause of your issue!
                        With the current exchange, would cost just over a grand to land a BW K04 with kit from ECS.
                        Damn...
                          Damn...
                          Yeah That is what I was thinking, then there is the tune as well, cause I am a existing APR customer they still charge $750
                          Guy seeing as you have a sale on now, could I get the car flashed with a K04 tune now, without having the K04 on it
                          MODS- TOO MANY
                            Your car wouldn't run for very long with the incorrect software in it.
                            Flash it & park it until you have the turbo on, then no issue.
                              Im looking at doing the ko4 upgrade in about two weeks after i install the FMIC.
                              Can you please tell me, Is it worth it???? the little info i can find, most say its not worth the power. The APR guy in monavale, sydney is kinda rude and doesnt really talk much!.
