Preventative replacemen of "weak link" parts prior to tune?
  • Preventative replacemen of "weak link" parts prior to tune?
    As the thread title suggests, what are people's opinions on replacing the parts known to be weak links at the same time as getting a tune done, given that the car will be about to experience increases boost?
    I'm now close to getting the car tuned stg 1. It's been logbooked serviced and just had the 60k major done. But the car is about to tick over 60k. Do you think it would be wise of me to have parts such as the DV and PCV done at the same time as a preventative measure, keeping in mind that it will be much more of a hassle to have these parts replaced later if they fail not long after the tune is done.
    Thoughts? Thanks
    MY07 GOLF GTI
    5-Door l Tornado Red l DSG l Leather l Xenons l MFD2 l TCP T.B.E l DNA stage 1
    DV is a good idea, its under the car & a pain to get to & the new VW version is near bulletproof.
    PCV is a little more expensive, but certainly worth checking. Just make sure the fuel filter has also been changed at the specified interval.
      Thanks Guy. Is the PCV more expensive because it's harded to change (more labour)? Looking on Dubaddiction, for parts cost alone the replacement VW DV and BSH PCV S1 fix are similar price. You do hear people talk often about DV's and PCV's failing. Is it that common and therefore worth doing, or am I over-eager and better off waiting to see if I'm an unlucky one to have these parts fail?
      The car has been logbooked serviced at the recommended intervals so should be no problem with fuel filter, spark plugs etc.
      MY07 GOLF GTI
        Hi Tom,
        With the newer VW DV's, they are most robust & reliable - the older style (rubber diagram) had a habit of failing.
        The BSH PCV fix actually eliminates part of the front PCV, its not a bad fix, but technically its not an upgrade (as to what it does - its a block off plate) - we find most PCVs die with mileage. The front PCV is on the front of the engine & easy to replace once you get your engine cover off.
        There is a rear PCV which can also fail & leak (although not as common). I have not seen any after-market replacements for that.
        If on a budget, do the DV first. Oh, check your service book for what has actually been replaced, we have seen stuff missed before!
          If the car is in great shape at the moment and the engine delivery power smoothly and consistently, no error codes, healthy fuel trims, etc., then you shouldn't need to replace a bunch of parts. Drop by a dealer or someone who has VCDS to give the car a quick check and I think you should be alright!
          Yes, the tune can reveal some weak links, but at least if it does, then you know which part to replace.
          VWWC Members - 2018 Special - ECU & DSG Remaps
          DNA Tuning Australia - Enquiries: info@dnatuning.com.au
            Thanks fellas. So Guy, as you've said above, is the BSH kit an appropriate solution for a failed front PCV? Or is there a better option to repair it?
            MY07 GOLF GTI
              Technically, a new VW one is the go personally. The BSH works OK though.
                Just out of interest - what is a DV - and a PCV?
                  DV = Diverter valve - it diverts the boost when it needs to.
                  PCV = Positive Crankcase Ventilation - part of the emissions system.
                    Ah ok thanks for that one
                      Agreed here, new one is a cracker, way different to the old one. Well worth changing, will stuff up tuned or not. PCV a big fail item also. Had a few not quite throwing codes but with a smoke test found to be junk. These cars were running rough on cold start. Ones that are obvious will be running lean and idling high
                      Jmac
                      Alba European
                        Are you talking about DV or PCV here?
                        As in, the older style OEM VW ones were/are no good and would throw smoke?
                        I have not found new OEM VW PCVs on any of the mainstream VAG tuning sites? Where can you get them? Plus, Dubaddiction is out of DV's... bummer
                        MY07 GOLF GTI
                          Give VW a call! New DV part number is here:
                          New OEM DV 06H 145 710 D - Diaphragm Removed! - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com
                            In terms of OEM VW PCV's Guy, is this what I should be looking at:
                            Volkswagen Golf V 2.0T > Engine > Emission > ES#8210 Breather Update Kit - 06F198203
                            or this:
                            Volkswagen Golf V 2.0T > Engine > Emission > ES#8209 Breather Update Kit - 06F198202
                            MY07 GOLF GTI
                              Just need to check which one will work for your engine. They should be able to let you know before ordering.
