adjustable cam gear???
  • adjustable cam gear???
    right...I sourced this autotech cam just recently,
    what im after now is an adjustable cam gear
    We are sorry, but this page cannot be found. If you have any questions or can't find what you are looking for, please contact us .
    has anyone had any experience with these?? any available to buy maybe
    im after some feedback on these and on this autotech cam as well
    cheers
    Hi there.. yeh i had one on my MK1 years ago... I think i still have it at home? maybe?.. im pretty sure i didnt sell it... will have a look and let you know...
    But yeh they are good... allowing a few degrees advance or retard..depending on what your after.. torque down low or up higher in the rev range.....
    like i said will have a look 4 ya.. mario.
      thanks mate...
      did u use it wit an aftermarket cam or with stock
      at the moment, this lumpy cam that i got is really good for the top end, but im not much of a rever so shifting the power down lower would be great for me
        i'v seen on few peoples signatures with "muller adjustable cam"
        is that from mullers at lakemba?
          Originally posted by deemoIII View Post
          thanks mate...
          Hi there.. i used an aftermarket cam.. cant tell you the facts... Lift/duration as i cant remember.. but yeh, good power increase... I may still have the cam too.. i do remember seeing one a few weeks ago all wrapped up.. i take it you are after one for your MK1?.. are you going to run Twin side drafts or a single.... Single is better up to about 5500rpm, then you do see the diff with the twins above that too about 9000-9500rpm..
          i used twin side draft 40mm delorto's... i should still have these somewhere too but i cant find them....ARRRRHHHH!!!.
          mario
            Deemo how much was your cam, jkust curious, I am looking into one for the vr6 where abouts did you get it from?
              mario
              its a mk3, as u can see my power to weight is not the best, thats why i need that down low increse
              swapt some parts with Matt, i would say $200 - 250 worth
                man this cam stuff sounds good, was looking at the link u posted deemo.. looks cheap less than $200.. i need sme low end torque too
                  I'm looking at something like a 268 270 cam for the vr6. I got quoted 2200 bucks for a schrick one
                    go Autotech steve, get sports valve springs and the cam gear while your at it to
                      New Valve springs are overkill imo (for the authors application only)
                        Cams are usually for NA cars - Sure you can put them on turbo cars but there is much more effective ways to spend money first.
                        And If you get a cam for top end power, you'll lose power/torque down the bottom end.
                          A cam isn't really gonna give you much more torque though. You want a VR6 mate.
                            after a few days of driving round with my new cam, i can give some feedback
                            it feels much smoother, all tho it seems to be slightly sluggish from down bellow, at 2500RPM starts pickin up quit good and it doesnt stop till 5000RPM; this is good considering that my stock cam was pickin up from 2000RPM but only with a short burst of power
                            the engine seems to be 'breathing' better, sound from the exhaust is stronger and it doesnt scream through 3500RPM like it wants to explode as it used to, now it makes that nice power-sound like rumble all the way through
                            all in all... money well spent. Thank you loon!
                            ...i just wonder now, what would that adjustable gear bring into the equation Mario, any luck with the search ??
