Originally posted by triode12
View Post
The Sprint Booster device, according to Sprint Booster themselves, "achieves a full throttle response 25% sooner than the stock configuration"
This means that when you've pushed the pedal down 75% of the way, you're already at 100% throttle.
In other words, if it takes you 0.2 seconds to push the accelerator pedal all the way down, because the Sprint Booster allows you to reach 100% throttle at the 75% position, you've reached 100% throttle at only 0.15 seconds.
In other words, you've saved 0.05 seconds.
View Post
As for your comments about merging, the Sprint Booster device, according to Sprint Booster, is not able to do anything that you couldn't already achieve without the Sprint Booster by putting your foot down further.
For example. If you are driving along at low revs, and your car requires 75% throttle to drop a few gears and pick up enough speed for you to merge, without the Sprint Booster, you'd have to push the pedal 75% of the way down. With the Sprint Booster, you can get away with pushing the pedal 50% of the way down. That's the only difference - again, ACCORDING TO THE MANUFACTURER!.
If you are in a situation without the Sprint Booster device where pushing the pedal down all the way is not enough for you to safely merge, then according to Sprint Booster, it will not help you. It will just mean you'll still be in danger whilst only having to push your foot down 75% of the way!
Originally posted by Fab_R
View Post
"If you have a track car where you spend most of your time near redline, Sprint Booster is not for you - Sprint Booster benefits are felt in the low to mid pedal travel." - Sprint Booster
So Fab_R, considering in the Golf R, when you use LC you have your foot planted to the floor, even according to Sprint Booster themselves, there will be no difference at all.
The only actual difference you will find, is that whether you have the pedal depressed 75% of the way, or 100% of the way, you will get the same LC results - because the Sprint Booster effectively makes the 75% to 100% pedal positions a "dead zone" (i.e. no change in signal).
I love all your enthusiasm. But you are still all going on about things that Sprint Booster themselves say are not possible.
