I have a Mk1 Golf [ well actually Scirocco - same thing ] and it has the standard Distributor. The Engine also has Extractors and Twin Dellortos.
So this Dizy should have vacuum advance and Vac retard.
In fact mine has no hoses connected. When checking with a timing light, there seems to be very little advance movement on the timing.
What is a good improvement for a Set up like this?
[ should I just connect the vac adv ? ] If I do connect the vac adv - does it need to be in a [ " Vac closed Off " at idle position.?????? ]
Thanks for " replies"
