I am going to sound super noob here but I was looking for a chip on Diesel Power and not sure what my stock tdi is like how many kw i know its a MKV5 golf 2.0 L tdi but wat i don't know is the kw how do i find out ?
ecu upgrade for 2.0 tdi
Hi tdiKD,
Just google it. Most TDI 2L will be able to recite 103KW/140PS & 320nm anyway! :p
FYI, the figure will be at the end of most road tests you find via a websearch. Basically as follows, for the Pumpe Diesel (PD) 2.0 TDI:
DIN-rated motive power & torque outputs, ID codes
103 kilowatts (140 PS; 138 bhp)
320nm torque.
Sammy here on the forum is probably a good person to ask about the Diesel Performance chip (IIRC). Bluefin's most popular from what I've seen.Wikipedia link
2.0 R4 16v TDI PD 103-125kW
This Pumpe Düse (PD) TDI engine was introduced to replace the older higher-powered versions of the 1.9 TDI. It is the first four-cylinder 16-valve double overhead camshaft (DOHC) Turbocharged Direct Injection (TDI) engine made by Volkswagen Group.
identification
parts code prefix: 038
engine configuration & engine displacement
inline four cylinder (R4/I4) Turbocharged Direct Injection (TDI) turbodiesel; 1,968 cubic centimetres (120.1 cu in); bore x stroke: 81.0 by 95.5 millimetres (3.19 in × 3.76 in), stroke ratio: 0.85:1 - undersquare/long-stroke, 492.1 cc per cylinder; compression ratio: 18.5:1
Everyone has an opinion and it's probably a case of finding out which best suits your needs.
If your car is under warranty or extended warranty (like mine is), then it's probably worth reading about peoples' experience with warranty hassles at their dealer, if the tune is detected, as it would likely be (if not resettable).Last edited by Bizi; 22-09-2010, 07:01 PM.Bizi's Jetta TDI: Blue Graphite w. factory leather & tint, plus + Enkei Racing NT03+M + Yokohama S Drive 18s, Koni FSD, Neuspeed coils, GTI RSB + brakes, InPro mirrors, VW navi, Modshack. Come for a drive through the twisties on Saturdaze.
Check out Winedriving forum/news for driving trips and wine tips.
I'd always go for a flash over the interceptor as you are limited as to what you can modify. You can't usually modify boost for example nor can you modify the smoke limiting or torque limiting tables within. I guess it depends on what your budget is and yes the interceptors do have their place and do give a good gain but if the dollar figure is similar to say a superchips/bluefin option I know what I'd choose. well actually I'd chose us but your in Vic so........
