16v engines for mk1.... (subject now)...head refitting
  • 16v engines for mk1.... (subject now)...head refitting
    gday folks new to site. kick ass work by the way
    right.. heres the story. had a stock golf relplaced motor for 1.8 16v running on microtech with custom fuel rail with large injectors, fuel pump and the rest. had for a bout a year then rings shat them self. slowly built up a audi 2lt with oversized pistons and a flowed 1.8 vw head new component through out. that lasted 2 days after the tune on the dyno, (sounded like a freekin 13b P port) at idle, was fast but was only running it in.
    shot a valve in to a piston and f***ed the whole lot.
    UPDATE: ive now had the bottom end rebuilt and head fixed but having trouble fitting it
    the golf is not dead.
    Isn`t there one in the buy and sell on this site? Block only. I have a cheap 1.8 8v, but its not the solution you want. Theres a guy in Byron i know who wants $1500 for a running 1.8 16v KR motor, complete, but no loom.
      sounds ok $1500 is aa fairly decent price, i already have mircotech setup in it so the loom isnt required, do u have a contact number or email addy for him. as i am chasing down all leads to find what i want. cheers
        You have P.M. Tell him I sent you and he may need to be persuaded to let you have it. Good Luck. If not, I am getting one soon, so will keep you posted.
          im also looking for info rebuilding a 1.8 16valve, i beleive the rings are shot and theres a bit of rust in the cylinders, can any body help me source the best parts for a 1.8 and who can rebuild the bottom end for cheap bucks, ,private or shop front, im positioned in canberra and will drive to syd to get it done....
            I can get you either 1.8 or 2.0 16 V engines from UK, let me know your preference and I will get a price for you.
            My shipper has just left UK, bringing me home 4 x Rocco 1 NOS hoods and a set of sills and rear arch repair panels. Tell me what internal new components you need for the re build and I will get my UK man to price that stuff up for you too. Container comes every 3 months.
            Prob better to e mail me the list on : bing_59@hotmail.com.
            Lots of MK 1 Scirocco's...
            Cheers,
            Grant...
              and to grab a bit more ooompfff from a 1.8 16v what about crank pullys, i have word and looked up lightweight/ billet crank case timing belt pullys, whichgive u 15+ ponies at the rubba and allowing the crank to be relived of some undeeded weight and spin faster, if any one has one on there car or know of someone who does, anygood? problems?
              might have to buy from over seas so would like to know befor hand
                its a wise move to use the lightweight pulley's more so if your giving the donk a hard rev..the VWM 16v uses lightweight pulleys for extra punch,they work fine with no adverse affects up to date..all preformance engines should seriously run this product..how much buckolleys?..in conjunction with a lightweight flywheel would be advised..cheers steve
                  will be getting a crank pully made up out of billet at a local machining shop will cost $100 as he is an ok mate, cant wait............
                  and is there a difference in sizes with the intake manifold for the 16v, ive seen some with the throttle body on the left and some on the right, am i right to say one is 50mm and one is 40mm or are the pipes the same and just the throttle body different?
                    The euro intake manifolds are 50mm the downtuned ones are 40mm.
                    Dunno about inlets. My 9a motors inlet comes out on the right side.
                      Inlet manifold
                      1.8 Inlets are the smaller ones whether left or right, whereas the 9a 2.0 is the bigger one.
                      Big is not always better and light flywheels are awful on road cars driving around the street.
                        early kr (1.8 ) from golfs in the late 80's had 50mm inlets
                        in the uk i have owned kr 1.8 with 50mm inlets and a 1991 passat 1.8 with 40mm inlets
                        the 50mm inlet car had less torque but revved harder and had much more power at the tope end
                        hope that helps
                          Torque
                          Sometimes we forget that other places are flat whereas we have lots of hills in Tassie even our local race track has a whopper so torque to us is good.
                            Re: Torque
                            i think torque is good fullstop!!!! you dont wanna always rev an engine to the stratosphere to reach its full potential.
                              measured mine up and there the 40mm ones with TB on the left side this has got me thinking in i want the 50mm one now but you say the 9a motors had the intake on the right side, do 50mm left side intake manifolds exsist?
                              so using a 40mm intake and a lightweight crank pully and windage tray could result in the same top end revs as the 50mm thus keepin the low down torque of a 40mm?
