2l 8v supercharge
  • 2l 8v supercharge
    Hi there
    i have just completed the installation of a 2L 8V (ADY) engine into my Caddy
    -i have a stand alone fuel management (gotech)
    -276 cam
    at the moment i am getting 105kw at the wheels
    i want to supercharge this setup with an Aisin sc12 supercharger (125mm pulley)out of a Toyota 4AGZE engine, can anyone assist with the following
    -max rpm of supercharger
    -max boost
    -would i need an intercooler
    -what size pulley would i need to get 10psi boost
    any other info would be much appreciated
    thanx
    alu
    (ajithh@telkomsa.net)
    hte supercharger has capacity of 1.2L per revolution. you can work out the pulley size from that given your own engine displacement and the pressure ratio you want (10/14.7 psi). i believe the SC-12 is considered OK up to about 12psi. max rpm for the SC-12 apparrently about 9000... dont quote me
    HTH
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
