Which cams and engine management for ABF ??
  • Which cams and engine management for ABF ??
    Hi all...
    Which cams are good for street ride? for ABF engine? (degree and brand pls)
    http://www.catcams.be/800x600/prod01...5?PN76612xx.js ( this ? )
    And which management system? How is the SMT6 or similar piggyback systems? what r u propose?
    I have Raceland 4.2.1 headers and custom coldair intake...
    I want about 190-200HP (engine)... with original intake and throttle, what r u propose for my ABF ?
    Thanks...
    I reckon a split profile set of Schrick 268/276 should get you that power along with a port clean up & couple of other mod's.
    Them or something with at least 270+ degree's.
    I'd do a search on other various forum's too eg. vwvortex etc. & check some other setups too!
    As far as engine management goes?
    I hope someone else can chime in with some info.
    I'd say strip it & go full programmable! haha
      i have microtech and im forever trying to get the idle right i say leave it standard and get it chipped especially as its your daily save for a turbo kit if you want power.
        Thanx mate, but I dont like turbo FWD cars, i like N/A engines, high rpms
          Is the head standard, as that has a pretty big affect on what cams you can run?
          In any case, there's absolutely no point modifying one until you have a shorter final drive ratio and a lighter flywheel, otherwise you're just pushing the powerband higher and it takes too long to get to it - they also fall off cam easily in tighter corners as 2nd gear, especially, is too tall.
            P.S. There are ways around the computer tune - no point changing it if you're staying with normal aspiration.
              which ways?
                Originally posted by SiLe-R View Post
                which ways?
                Are you in Turkey, or Germany (which it says on Vortex?)
                If you're in Western Europe, you need to get on the motorway and take the car to JD Engineering (Jereon Dik) in The Netherlands who can live tune the ECU... He's also built some of the fastest VWs in the world.
                If you're in the East, you need to see Basil Daham from Daham.org who will setup a plug and play piggyback system under the table for a very good price.
                Any bench-tuned chip isn't much good with cams (unless it is one of the engine upgrade packages, which you can buy from DBilas - includes a camset and matched chip) as you really need to live tune the engine.
                In any case, the setup of the head dictates which cams you should run. The 268/276 isn't ideal in a more agressively ported head as the poor exhaust port flow has usually been fixed (meaning you needn't hold the valves open for longer to account for it). In a very mild or standard head, the bigger exhaust cam is reasonably good. The ABF is quite easy to port compared to the KR one as there's more material to work with - you are removing material, just as much as reshaping the port, whereas with the 1.8 heads, you are mostly reshaping (within reason).
                There are some very good gains to be had with headwork, but even more with improving the gearing. 3.67 is the standard final drive ratio - the most popular upgrade is a 3.94, which is a good compromise between acceleration and motorway comfort. 4.24 makes a very quick car, but its not ideal in Europe, I don't think.
                  Anyone ever try megasquirt on VW's ?
                    I'm pretty sure pepperwhite has with his MK1 16v...
                      I am from Turkey, Vortex isnt my accaunt... its my friend accaunt
                        catcams says that about 279 / 268°...we can use stock follovers, retainers and springs...
                        is it right? Can I use stock?
                          up
                          is it right?
                            You can use stock springs and retainers with those cat cams, but if your serious about power gains dont just limit yourself to cams and ecu modifications.
                            It all depends on your budget but their are so many excellent modifications to gain power.
                            Bore and hone it 0.020" oversize with 11:1 forged pistons (wiseco are a good choice with N/A engines). Fully lighten and balance your crank, rods, pistons and especially your flywheel, . You wont need forged rods unless your planning to rev it past 7500rpm.
                            If your considering an aftermarket ecu also consider throttle bodies which combined with the correct porting and polishing can acheive massive top end power. Get heavy duty valve springs and titaninum retainers with 0.5mm oversize vavles. An adjustable cam gear to move the power curve up the rev range.
                            Cat cams make some really serious hollow cam grinds which require solid lifters aswell.
                            After market ecu's are the best way to get the most out of the modifications made, with an experienced tuner you will not only see great results on the dyno but drivability that counts aswell.
                            Mk2 GTI 2 door 1.9l 8v turbo 1st mk2 1st engineered water vw nats 09
                            Mk1 twin eng twin turb
                            scirocco gti 2.1l 16v turb 6spd
                            Audi A4 B5 1.8t
