Installing Aftermarket Wheel + Boss
  • Installing Aftermarket Wheel + Boss
    Morning Guys,
    Went to put on one of my Chrissy prezzies this morning, and when i place the Boss kit onto the Mk2 steering column it seems to want to short something out. I got a little crackle and some tiny smoke. So I quickly took it off. Everything works fine, no shorts. But any ideas what it could be??? I'm at a loss when it comes to car electrics... and dont want to blow anything.
    Thanks in advance..LVD
    If you look at your steering column you should see a small, thin spring steel plate sitting up near the middle, this contacts on the brass ring of your original boss and a wire with spade connectors in the centre completes the circuit when you press the horn.
    I would check that this is what is occuring and that your new boss is exactly the same as the original.
    Mk2 GTI 2 door 1.9l 8v turbo 1st mk2 1st engineered water vw nats 09
    Mk1 twin eng twin turb
    scirocco gti 2.1l 16v turb 6spd
    Audi A4 B5 1.8t
      X2 and check your fuses there is a good chance your horn fuse needs replacing now. I wouldnt replace it until after you fit the boss kit and steering wheel so you dont burn another one.
