Copied from another site.
Lot's of good info.
SUZUKI
Make/Model: GSXR600
Year: -01
Number of Tb:
Inside Diameter: 38mm
Center-Center (left to right from behind):
Overall Length:
Outside Diameter (intake):
Outside Diameter (filter):
Separate casting:
Injector Make/Model:
Flow Rate (45psi/100%):
Fuel Rail Inside Diameter:
Additional Info:
Make/Model: GSXR 600
Year: -02
Number of Tb: 4
Center-Center (left to right from behind): 80-80-80mm
Overall Length: 83mm
Outside Diameter (intake): 44mm
Outside Diameter (filter): 45mm
Separate casting: Yes
Injector Make/Model: Keihin KN4, 0J07 AAA A
Flow Rate (45psi/100%): 240cc/min?, 13Ω
Fuel Rail: Alu casted, Inside diameter 6mm (9mm in the ends)
Additional Info: sec. throttles controlled by ECU.
Make/Model: GSXR 750
Year: -98, -99
Number of Tb: 4
Inside Diameter: 46mm
Overall Length: 91mm
Outside Diameter (intake): 54mm
Outside Diameter (filter): 54mm
Injector Make/Model: Keihin,
Additional Info: No sec. throttles.
Year: 2002
Number of Tb: 4
Inside Diameter: 42mm
Center-Center: 80mm
Overall Length: ???
Outside Diameter (intake): 48mm
Outside Diameter (filter): 52mm
Fuel Rail Inside Diameter: 2.4mm
Make/Model: GSXR750
Year: -06
Number of Tb:
Inside Diameter: 40mm
Overall Length:
Separate casting:
Additional Info:
Make/Model: DL1000 V-Storm
Year: ?
Number of Tb: 2
Inside Diameter: 45mm
Overall Length:
Separate casting:
Additional Info: dual throttle plate
Make/Model: GSXR 1000
Year: -02
Number of Tb: 2
Overall Length:
Separate casting: No (dual Tb´s)
Flow Rate (45psi/100%): 230cc/min
Make/Model: GSXR1000
Year: -03
Number of Tb:
Overall Length:
Separate casting:
Additional Info:
Year: -03
Number of Tb: 4
Inside Diameter: Tapers from 50 to 42mm
Overall Length: 90mm
Outside Diameter (filter): 53mm
Additional Info: Pic without secondary butterflies and fuel rail.
Make/Model: GSXR 1300 (Busa)
Year: 1999-2003
Number of Tb: 4
Overall Length:
Additional Info:
Year: pre 2002 ?
Number of Tb: 4
Inside Diameter: 42mm at injector end, tappered from 51mm at air horn end
Outside Diameter (intake): 55mm
Flow Rate (45psi/100%): ?
Fuel Rail Inside Diameter: PA66-G35
Additional Info: no secondary butterfly
KAWASAKI
Make/Model: ZX6R
Year: -02
Number of Tb:
Overall Length:
Separate casting:
Fuel Rail:
Additional Info:
Make/Model: ZX6R 636 B1
Year: 2003
Number of Tb: 2
Center-Center (left to right from behind): 75-75-75mm
Outside Diameter (intake): 52,6mm
Outside Diameter (filter): 50,8mm
Injector Make/Model: BOSCH 280031V
Flow Rate (45psi/100%): 245cc/min
Additional Info:
Make/Model: ZX6R
Year: -05
Number of Tb: 4
Overall Length:
Separate casting:
Fuel Rail:
Additional Info: Oval TB´s
Make/Model: GPZ750 Turbo
Year:
Number of Tb:
Inside Diameter: 34mm
Overall Length:
Separate casting:
Additional Info:
Make/Model: Z1000
Year:
Number of Tb:
Inside Diameter:
Overall Length:
Separate casting:
Additional Info:
Lot's of good info.
SUZUKI
Make/Model: GSXR600
Year: -01
Number of Tb:
Overall Length:
Separate casting:
Additional Info:
Year: -02
Number of Tb: 4
Year: -98, -99
Number of Tb: 4
Year: 2002
Number of Tb: 4
Center-Center: 80mm
Overall Length: ???
Make/Model: GSXR750
Year: -06
Number of Tb:
Overall Length:
Separate casting:
Additional Info:
Year: ?
Number of Tb: 2
Overall Length:
Separate casting:
Year: -02
Number of Tb: 2
Overall Length:
Year: -03
Number of Tb:
Overall Length:
Separate casting:
Additional Info:
Year: -03
Number of Tb: 4
Year: 1999-2003
Number of Tb: 4
Overall Length:
Additional Info:
Year: pre 2002 ?
Number of Tb: 4
KAWASAKI
Make/Model: ZX6R
Year: -02
Number of Tb:
Overall Length:
Separate casting:
Fuel Rail:
Additional Info:
Year: 2003
Number of Tb: 2
Additional Info:
Make/Model: ZX6R
Year: -05
Number of Tb: 4
Overall Length:
Separate casting:
Fuel Rail:
Year:
Number of Tb:
Overall Length:
Separate casting:
Additional Info:
Make/Model: Z1000
Year:
Number of Tb:
Inside Diameter:
Overall Length:
Separate casting:
Additional Info:
[/quote]
