Supercharged mk1
  • Supercharged mk1
    What do you guys think? i have a lil supercharger lying around was going to see if i should fit her up... looks like i could moun t it fairly easy and get some pipes made up at the local exhaust shop... or even buy the bend and weld them up myself...
    i also have a little intercooler so go with it will get pics of it soon.
    here are some pics of the charger and where i though would be a good spot for it.
    the crank shaft pulley already has the end made up to drive a belt and the teeth on the supercharger fit that...also have the belt so i just have to make up some mounts for the charger.
    is that a toyota 4AGZE charger?
    Looks tiny, might add restriction higher in your rev range.
    mk2 GTi 16v
    Corrado G60
      its off a 4AGZE motor yeh. its fair small can run up to 6psi i think. thats ok high revas wouldn't make much power anyway...stop making power about 5,800
      anyway
        good idea or not so good idea?
        or better of selling it and turboing it?
          You'll have to upgrade your K-Jet with increase fuel pressure & boost sensitve warm up regulator.
          You'll also have to fit a timing retard for you ignition!
            i wouldn't run the piping through the box i would have it split just after it leaves the box.
            I dont understand about the fuel side? its already running at 8psi...from the k-jet pump. from what i understand
              I don't get it.
              If you run K-jet with any forced induction the piping has to run from the airflap to the unit, whether it is a turbo & supercharger & then onto the intercooler (if fitted) & then the throttle body.
              K-Jet system pressure should also be 5bar & control pressure should be from 1.2bar (cold) to 2.8 bar (hot) Approx. figure's
                I don't get it.
                oooo...
                so it doesn't run from the charger to the throttle body and the air box just draws air?
                hang on i will draw a pic of what is in my head!
                  oooo...
                  Yeh.
                  The piping run's from the K-jet gear, to the supercharger & then onto the throttle body.
                  But the K-jet still need's boost reference to supply the right amount of fuel.
                    this is what im thinking in my head...
                    or does it have to go like this?
                      Read it again. Carefully!
                      Air comes in through the air filter, through the K-Jet airflap, onto the inlet of the supercharger, ou tof the sc & onto the throttle body/intake manifold
                        ooooooo i get it now and if you have the intercooler that goes before the sc?
                        so what would i have to modify other than the piping?
                          intercooler after sc
                          MK1 4door
                          MK2VR6
                          MK3VR6
                          Transporter
                          1st place, stock MK3VR6. Vw nationals 07
                          2nd place, mod MK2VR6. Vw nationals 09
                          and untold wrecks
                            like this , very quick pic
                            MK1 4door
                            MK2VR6
                            MK3VR6
                            Transporter
                            and untold wrecks
                              ok i get it! learn stuff new everyday! i'm new to all this sc and turbo stuff.
                              with such a small supercharger should i bother with the interchiller?
