G-8VXWWTRHPN quality torque wrench - VWWatercooled Australia
  • quality torque wrench
    Gentlemen, It is about time I purchased a torque wrench and stopped relying on my calibrated wrists.
    Any thoughts on a good quality wrench would be most welcomed.
    More care is now required with the Golf Gti 2007, and I am getting older.
    Thank you in advance
    Regards john
    I got a reasonably priced Kinchrome one about a year ago and I have not snapped an alloy stud since. From memory it was somewhere near $100.
    Welcome John.
      Got the same/similar one, also roughly a year ago. Got it from Bunnings and it was the only one there, ~$89. Had a fact sheet that detailed how accurate it was (IIRC, mine was less than 1Nm off), and also provided details for getting it recalibrated. SuperCheap sells a visually identical one for considerably cheaper, though I don't know how reliable it may be.
      Present: Mk3 Golf variant.
        Warren and Brown
        or Norbar
        Pete
        7? MK1 Caddy
        79 B1 Passat Dasher Project
        12 Amarok
          I prefer the Warren & Brown dual signal deflecting beam type. I have 3 of them, all different range of course. The graduation you will need is in Newton metres, not sure if they are still sold with any other.
          Numerous Mk1 Golf diesels
            Bit of a problem there mate as you need a degree type torque wrench with most later VW stuff.
            I use the Snapon one but its damn expensive!!!
            Probably a good normal tension wrench would do and a degree fitment tool as well is required for occasional jobs.
            Andrew
              Andrew
              Yes, that's what I do. I can't afford to replace mine with new ones. While the use of stretch bolts seems to be increasing there is still a lot more standard screws/bolts where a normal torque wrench is needed.
                my snap-on one is awsome
                but i have a tengtools one for wheel nuts and thats pritty good for the money
                (]/_ O _____ O _\[)
                "'(O8o)=\X/=(o8O)
                [__|========|__]
                  Sidchrome is ok too.
                  There is also Stahlwille.
                  Performance Tunes from $850
                  Wrecking RS OCTAVIA 2 Link
                    i have a CAT torque wrench, can get you one for a good price if interested
                      You should start off with a price range first.
                      They can go from bugger all to bugger me dead! That much!
                      What size are you after 1/4", 3/8", 1/2", 3/4"?
                      What would be the tightest thing you want to do up?
