am going to build an exhaust manifold for the 16v i need a little help in the runner diameter??i am going to go 4 to2 to 2somewhere under the car, a nice long system, i need help in which diameter tubing????
thanks
Originally posted by Preen59
be carefull of your gear lever when your measuring it up on the car, be sure to have the gears in 1st and 2nd making sure it dosnt hit the extractors/exsaust, its a pain when you have to take a angle grinder to your newly made extrators...
2inch pipe is probably the most commonly used..
If your interested i made some extractors to suit a 1.8 16v in a mk1, i havn't used them at all, they are 1.6mm wall thickness mild steel mandrel bent 4-2-1with two flexable joints and go into a 2 1/2" collector. I have a stainless 2 1/2" system to go with it...
Mk2 GTI 2 door 1.9l 8v turbo 1st mk2 1st engineered water vw nats 09
Mk1 twin eng twin turb
scirocco gti 2.1l 16v turb 6spd
Audi A4 B5 1.8t
