Here's an interesting project someone might be interested in. I'm running a 1.8L from a mk3 golf in the TS Passat ('75) and currently i'm using the distributor from the 1.5L i took out. I've built up some electronics to run the 1.8L distributor which is a hall effect sensor triggered system. The problem is, I need to program the advance curve into the module for this to work and I don't know what it is! I was hoping somebody would be able to point me in the right direction for the advance curve for the ts distributor or the mk3 electronic system curve. Either would be a great starting point as currently i have none!
Philip
Philip
