OK i did a kr 16v conversion with K-jet in my mk1, and still trying to get it to run right.
My problem at the moment is that when i take it up to around 5500-6000 rpm @ full throttle, the engine seems to starve and spit. It pulls really well until i reach those revs.
I don't think its the timing because the longer i drive it, the engine seems to spit at lower revs at full throttle. When i back off the throttle a bit she runs ok. Plus i can get it to go up to 7500 without spitting by backing not opening the throttle all the way.
So i'm guessing i have a prob with fuel pressure due to a crappy fuel pump that seems to loose its pumping power the warmer it gets.
Does anyone think the same way or am i heading down the wrong path.
Ps what is the fuel line pressure supposed to be for the k-jet system and is there any easy way of increasing line pressure from the fuel distributor?
 Starts spitting at 6K rpm
