So I've been scouring the internet to try and see what's causing my high fuel consumption of 10lt per 100km constant average.
I'm currently running an APR Stage 2 tune, exhaust, intake, intercooler, R8 coil packs and BKR7EIX plugs in my Polo 6R. The high consumption began after fitting the R8 coil packs. So one would think they are the cause but I've not seen anything online to indicate this would be the cause, more so the opposite in fact.
Two other interesting things to note.
I'll have the oil sensor replaced (the wiring has been checked and tested), but I was wondering if anyone has seen this behaviour at all?
- The same day I fitted the coils my oil sensor started throwing fault codes (implausible signal) and the oil temp indicator on the dash is all over the place.
- The fuel consumption indicator is stuck at 10lt / 100km for the long average and 10-14ish on the short range. The long range doesn't change, not even 100ml. It's always 10lt and I get about 400km a tank.
