G-8VXWWTRHPN Technical Terminology and Information - VWWatercooled Australia
  • Technical Terminology and Information
    This is a thread for technical information and terms automotive related. And more specifically, technical info and terms for Volkswagen vehicles.
    Engine and drivetrain terms
    8v- The term commonly used to describe an engine with a valvetrain containing 8 valves. In most cases, this will be a 4 cylinder, ie: 2 valves per cylinder. 1 inlet, 1 exhaust.
    16v- The term commonly used to describe an engine with a valvetrain containing 16 valves. In most cases, this will be a 4 cylinder, ie: 4 valves per cylinder. 2 inlet, 2 exhaust.
    DOHC- Double Over Head Cam. This is the term used to describe an engine with 2 camshafts in the head, operated directly over the valves. One camshaft operates the inlet valve train, the other operates the exhaust valves. DOHC setups are mainly used in multi valve engines. In the case of the VR6 engine, due to the staggered bores, the two camshafts actually operate the inlet AND exhaust valves for the front or rear cylinders.
    Multi Valve- This term describes an engine that has more than 1 inlet and/or exhaust valve per cylinder. Eg, a 16v, 4 cylinder engine.
    VR6- Vee Reihe Sechs. Which, when translated to English, means Vee Straight Six.
    Common Abbreviations
    VAG- Commonly referred to as "Volkswagen Audi Group" or "Volkswagen Automotive Group". The correct term is actually "Volkswagen aktiensgesellschaft", which means "Volkswagen Company Incorporated".
    This will do for the moment, i have just written this in to kick this thread off, and I will add more later on.
    If you have more useful terms to add, please PM either me, or a moderator and the information will be added. Please do not them in this thread as i would like it to stay as uncluttered as possible, and keep the information restricted to a minimal number of posts.
    EDIT:
    On second thoughts, post your questions here, they will be answered and the info will be added. Please, no chit chat though.
      VAG = ? (character limit)
      No more running wild...
        Volkswagen Audi Group.
        Dave
          volkswagen aktiengesellschaft
          2x Caddy, 1x Ducato
            translation?
              Volkswagen LTD pretty much. like a public company with limited liability. quite similar to GmbH
              87' MK2 GTI
              13' MK7 TDI
                Yeah i served my apprenticeship with VAG and obvious answer would be Volkswagen Audi Group but it is in actual fact not. The correct answer is Volkswagen aktiensgesellschaft which means company incorporated. You will find if you look at the other big brands like BMW, Merc and Porsche they are in actual fact BMW AG , Mercedes-Benz AG and Porsche AG and V AG.
                Hope this clarifys , i ceratinly had it drummed into me in the regimental days at dub.
                JMAc
                Alba European
                  how come my VR6 engine says DOHC on the engine trim yet both its cams operate inlet and exhaust valves? hehe sorry cant help myself
                  FOLLOW US ON FACEBOOK
                    Fixed smarty pants wishbone legs..
                    Also added VAG.
                      i like the sound of VAG preen..
                      another interesting note. VR6 stands for Vee Reihe Sechs. which means Vee straight six.
                      87' MK2 GTI
                      13' MK7 TDI
                        Very true.. I'll add that.
                          EOI? in the for sale sections
                          dom
                            dom
                            Expressions Of Interest
                              ahh i see
                              fair enough
                              dom
