Hi all
Any one know about converting a hydraulic lifter head to solid lifter and then bolting to a 1.6 block.
I understand about blocking the extra drain back and reducing the diameter of the other.
I'm assuming that through machining you could organize the comp ratio.
Would you have to block any other galleries off like the spray thing which is where the bearing cap would be on the solid?
Would you use solid lifter cam and buckets and shims ?
Any ideas would be thankfully received.
Happy new year Geoff
