changing the rivets for bolts is a sinch, You may need to fabricate a puller to split the trans case tho.
If you go the route of installing a quaife, pelo or wavetrack you will need to check the bearing preload on the bearings during installation and re shim to get it correct. ( shims from VW ) See Brian's web pages ( broke)
Bolts are available from ARP also. (204 - 3001)
Rubber brake boot is still available from classic vw ( VW Heratige )
VW Heritage for VW parts and accessories
