Just cos i didnt plan for high performance doesnt mean that i wont try for it. I guess that i know myself!
Project Turbodiesel
A quick update on the project, the motor is home from the engine builder. It has the oil squirters installed. I have an intercooler from a saab, and a massive radiator from and Audi. Today I marked the toledo flywheel with a TDC mark and should have the motor and gearbox in this week! On the way from Canada I have a TD air filter assembly, CCV system and injector lines. All I need now is a k14 downpipe and exhaust.
Photos to come.....Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
Hey Matt.
Thought I'd add this on here for reference sake & hopefully someone out there can also add some info.
I found the engine codes for the diesel engines in the US Spec caddy's for you
JK - 1985-90
ME - 1990-92
Rod bolt # 037 105 425
Rod nut # 068 105 427
This is the bit of info I'm not 100% on though sorry Matt.
The tightening torque of the conrod nuts (the conrod's have pressed in rod bolts & then the nuts are tightened as below)
33 ft lbs - NA form for the engine code above.
For the turbo'd diesel (AAZ) They are conrod bolts
depending on chassis # or bolt size
028 105 425G M8x1x42
028 105 425C M8x1x45
22 ft lbs +1/4 turn is - FI/Turbo (stretch bolts)
Fitted 2.5" mandrel bent exhaust and tidied up engine bay. It wont be long now and there will be white smoke at the front, black at the back!Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
Donor motor, 1.6D
Long motor ready
Engine build bits inc turbo pistons, valves and oil pump
Thermal/friction coated pistons
Motor is in!
Cylinder head with new seats and guides
mild porting
good work, glad to see it's coming together!
Looking Good Mate. Nice to see a build thread with some action and pics.
Keep the updates coming.sigpic Camden GTI Performance. VW / AUDI Specialists
